any body know whats going on here ........
Started by fatkat, June 18, 2009, 05:52:21 PM
fatkat
the maps a bit small sorry .....
so whats been happening is that I'm getting aircraft plots  that don't produce polar plot info nor do they track across the map ...
as you can see they are close to the wash  and at first I considered it military activity
any way the two errant plots are in the alltitude lollipop graph  with no corresponding map plot ....I had numerous instances of this yesterday and this afternoon  ranging from low level to high and from one to four aircraft seemingly ...also displays blue red and green
any thoughts ?
fatkat
and this one just now
[attachment deleted by admin]
#2
Haven't you already asked, or is this something different? - http://www.airnavsystems.com/forum/index.php?topic=2889
fatkat
yes..........
but saw the screenshot forum, I thought that was what it was for rather than cluttering up general discussions ....is there an issue  ?
if so you better say  quick ...
fatkat
ok......
nobody any ideas ?
yesterday I raised my mast by 3m  ...
this has had the effect of pushing these "false plots[fp] " further east approx 10nm
I also calculated that the lowest altitude I can recieve line of sight at this range is about fl250..  due to tree and buildings close to me ....effectively some of these fp are below my horizon ...suggesting an origin much closer to home ?
couple this to the fact that little or no military stuff is moving over the weekend ..just about rules that out
there seems to be little or no correlation between plots on screen[signals recieved] and the FP's  so it would seem  that a reflected signal or ghosting is also unlikely. Add to this the fixed nature of the plots geographically  a moving  transmiter is likely to prodce a moving reflection ?
any thought  would be gratefully recieved ....
I have a new set of pics showing the new location  if anyones interested .
Purple rain and spurious plots are fixed in the v3.0 beta.  Have you tried the v3.0 beta, does that solve your problem?
fatkat
cheers......
don't think its purple rain  having read the various posts ....it certainly doesn't look like the examples posted ....I'm getting nothing anomalous on the map just the height plot.
software is 2.01
firmware is 2.03.1
so no to version 3  yet [having only had the box less than a month] I'd rather get to know the thing first  foibles and all before I explore  v3.0 beta
I'm assuming  that your not picking these  up ?[tarbat ] I saw from your polar plot that you can see down the east coast ..
that again would suggest a local cause  .....
fatkat
following tarbats advice ...I installed verision 3 beta
sorry to say I'm picking up the same effects from a similar position ...only they flash off and on quicker ....???  so might struggle to get a screen shot !
fatkat
just a thought  ......as I'm still getting these at the rate of  one or two per minute ...but with v3  they only linger for about half a second.
could they be reflections from a site that fixed in relation to my area .....
the only thing that I an think of that would give aregularish  signal would be reflection from a wind turbine blade .....but this of course is total speculation
I must assume that I'm the only person getting this phenomena  ?
and therefore its probaley some quirk of location and antenna foibles
malc41
15 Miles East of EGNJ
fatkat
nottingham  approx  12nm ne of east midlands airport
Ozoneflyer
Dear Friend : One would almost think that While we were sleeping a Secret Government Swap took place and the people who are Now at the Helm are some how operating Made to look like commercial airliners that are Flying North / South Grid patterns leaving behind Only "Chem-trails" But when calls are Made to Local Airports or the FAA or even Santa Claus to at Least find out what Where Or even Why the SOP seems to be the exact same No Matter what YOU THOUGHT your eye's were watching take place You witnessed "Simple contrails" But what asked since when do "Contrails" Hang around for the afternoon turning a  Once Beautiful cobalt blue sky into an Ugly Grayish soup ? So whatever I witnessed looking thru my Spotters scope was an Illusion PERIOD !!! Maybe you had the same Dillusion ????
