Author Topic: RELEASED - AirNav RadarBox 2009 - 3.0 Beta  (Read 372531 times)
Re: RELEASED - AirNav RadarBox 2009 - 3.0 Beta
« Reply #150 on: June 19, 2009, 02:31:47 PM »
Has anyone checked out this feature that was mentioned in the Official full list of suggestions/improvements:
- Possibility of writing custom labels on map;
Can't seem to find this one......
Look in Preferences
« Reply #151 on: June 19, 2009, 02:36:45 PM »
Well i here the controler give them a sqk code, and they sqk ident, and he tells them "radar contact" with position and crossing alt.
That indicates that they have a Mode A/C transponder, but not necessarily Mode S.
EGNXR
« Reply #152 on: June 19, 2009, 02:37:05 PM »
Another bug.
I cannot get the split cursor that allows the interface to be made wider or narrower. This is on both XP and Vista PCs.
Tom
Hi Viking9,
If you click on the very edge of the menu it allows you to drag, it just does not show you the icon your used to.
Cheers John
Based in Derby 5Nm NW of EGNX
Levery
« Reply #153 on: June 19, 2009, 02:39:32 PM »
Cool thanks!
Located 10 km SE Hato Airport (TNCC)
viking9
    • Aircraft Photography
« Reply #154 on: June 19, 2009, 02:40:52 PM »
Cheers John, that works on my PC but not on my laptop. So it's still a bug as it worked before :o))
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
vruma
« Reply #155 on: June 19, 2009, 02:48:46 PM »
Despite setting a custom legend in the format as the example sates, enabling the custom legend in preferences and in the map menu, i can't see it. Has anyone succesfully set it so it does really appear?
Levery
« Reply #156 on: June 19, 2009, 02:55:39 PM »
Now that you mention it will there ever be an ability to recieve Mode A/C transponders, or is it because Mode-S is more widely used?    So that we can recieve those also....
« Last Edit: June 19, 2009, 03:11:53 PM by Levery »
jmhayes
« Reply #157 on: June 19, 2009, 02:58:34 PM »
... they are probably legit 'dupes' ...
Any chance of AirNav telling us what they are using for an algorithm here?
I don't know what algorithm is either, but a good rule-of-thumb ...
Oh sure, I can think of ways to do this too ... I'd just like to know what AirNav is doing.  Since they aren't generating STA messages (in fact, nothing other than "MSG,1" and "MSG,3"), on port 30003 it would be nice to know what they are doing.
radarspotter10
« Reply #158 on: June 19, 2009, 03:10:59 PM »
Cheers John
[/quote]
hi john
thanks john was looking for that, working on all my computers OK.
from pat
Manuel Mendes
    • Manuel Brito Photography
« Reply #159 on: June 19, 2009, 03:23:52 PM »
Another thing: it would be great to select the aircraft by clicking on it and not when the mouse passes over it.
bailey_uk
« Reply #160 on: June 19, 2009, 03:40:19 PM »
Can anyone confirm if 'Lakey' is in the correct position. I used to be able to cover all the Scottish Central Belt airports and position 'Lakey' on one map view on the old version but with version 3 it's proving to be a bit of a problem trying to position the map correctly with the names of the fixes showing. I've tried various zooming in and out without much success. It looks as if 'Lakey' is positioned too far south now.
Hi, Lakey is my local Waypoint!
One way to make sure if it is in the right position is to add this attached .out file which I made personally last week, which is of Lake Windermere.
'Lakey' is about 2 Nautical Miles south of the lake, and slightly to the left. Also, its  in a direct line between DCS VOR, and MCT VOR.
Hope this helps,
James
    • Rod's RadarBox Downloads
« Reply #161 on: June 19, 2009, 03:54:59 PM »
Vruma - yes, custom legends work fine for me. I seem to remember in another thread (or maybe this one) that there may be a problem with international settings and decimal indicators. Changing settings there may help.
Can't find the thread/post at the moment, though.
bailey_uk
« Reply #162 on: June 19, 2009, 03:56:50 PM »
Make sure that is is a decimal and not a comma?
James
vruma
« Reply #163 on: June 19, 2009, 04:01:36 PM »
Rod & James, thank you both. Changing the regional settings of windows from a comma to a decimal did the trick. Now its working.
bailey_uk
« Reply #164 on: June 19, 2009, 04:11:43 PM »
I struggled to find it also Rod! Post #67 of this thread ;-)
