RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 18, 2009, 08:36:32 PM
Quote from: EMA on June 20, 2009, 03:14:16 PM
Quote from: Andy Frost on June 20, 2009, 03:11:13 PM
Maybe someone can enlighten me, I don't understand where all these extra fix points have come from in 3.0 Beta and why they are necessary.
I think it has been mentioned somewhere in this thread by Airnav but it is getting so long I cannot find it.
It's probably just a bulk import from a nav aid database.  I don't tend to have the fixes, VOR's or NDB's selected on.  I also switch the airports off unless I'm zoomed right in to watch the approaches and departures.  I don't "need" all these fixes, but there certainly do seem to be an awful lot of them.
EMA
Quote from: AirNav Support on June 19, 2009, 08:18:34 PM
vruma,
Thanks we are aware of those. The sluggish response with all the fixes is normal :) as there is soo many that it has trouble. A few customers and Professional customers really wanted this.
We will discuss whether there is ways to limit them internally.
Andy, here is the post.
#257
Just as FYI for you guys. Here are the bugs being looked at present
Serious:
Some machines software does not start with error. (Comptability fix)
Aircraft on map disspearing and returning with zoom
High:
Full screen and then return does not show map/aircraft
Duplicate Entries of flights in MyLog, required longer timeout or capabilty for user to change timeout
Check route alogrtithm and sometimes wrong routes are being displayed
Range alerts not working
Low:
Font issue with commas and dots in custom legend
Filter to last ten minutes or one hour in MyLog Missing
No icon to resize interface window shown
Entries of closed maps in windows menu
Error message in preference menu
The 'execute a file' box is always ticked in alerts
Text showing the aircraft details to the right of the photo of the aircraft is getting clipped
No up and down icons for Flights
Quote from: Andy Frost on June 20, 2009, 03:11:13 PMA small point concerning zooming. Zooming the map in and out with the + or - keys, mouse wheel or right-click menu isn't consistent. One step of zooming in followed by one step of zooming out doesn't put the map back where it was but zooms out one extra step.
One step of zooming out = two steps of zooming in.   I quite like it like that, since you can zoom out quickly, and then slowly zoom into the area you're interested in.
snowman
I have also noticed another "feature" in that if you move the mouse over different parts of the map, the local time shown in the bottom left hand corner changes e.g. putting the mouse over the sea puts the displayed time back one hour.
Not sure if this is normal behaviour
Suppport - to add to the low list - the Wander Weather toolbar has a side-effect - the last line of the grid can't display properly when the Weather toolbar is up alongside the menu, so I lose a line:
Jollygreen
Quote from: EMA on June 20, 2009, 10:26:36 AM
Quote from: dumpty on June 20, 2009, 08:56:50 AM
This is a wierd one;
On the map display i keep losing the plane symbol and info from any new planes coming on to the display particuarly fom the bottom of the screen going north.If it weren't for the trails I wouldn't know they were there.
However if i zoom in or out the plane symbol and info appear no problem!
Keep up the good work airnav.
Simon
Looks like a similar problem to what I have experienced and posted earlier. I have seen this in the closed beta and the open one. I guess others are missing this because the aircraft are not there unless you zoom in/out. They do appear in the aircraft list but not the map so it looks like a map redraw issue.
UPDATE
After posting this I looked at my map and no aircraft were visible just a few odd trails, zooming in/out and 8 aircraft popped out of nowhere.
I have had the new version running all day, even though it has been totally overcast here in Chelmsford and nothing has been seen visually. That said, I have noticed like many others that floghts disappear and only return when I zoom in or out. Is this being looked into AirNav?
Nigel
Jollygreen
Thanks Rod, had only got as far as page 16 when I posted ny comment as I was seeing similar issues.
Nigel
Jollygreen: you will be contacted by email today about this one.
Jollygreen
EMA
Quote from: Jollygreen on June 20, 2009, 04:21:46 PM
Nigel
Nigel, do you also see trails with no aircraft at the end of the trail?
Jollygreen
Can't say that i have notice that one but will keep an eye out when I am using it tomorrow, if the weather is good.
dumpty
EMA
That is exactly what I am getting,trails with no aircraft.
EMA
Quote from: dumpty on June 20, 2009, 06:13:55 PM
EMA
Okay, it is like the aircraft have timed out but in reality they are there when a map refresh is performed.
