RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 18, 2009, 08:36:32 PM
The're not moving very fast, that's for sure :-) - I was going to do the screenshot at Manchester, but overflying aircraft got in the way.
Do I take it from your question that you're not seeing the same thing, Tarbat?
EMA
I have seen this a couple of times at EGNX they are always network aircraft that have not timed out. If I switch network off/on they disappear.
#317
Quote from: RodBearden on June 22, 2009, 03:19:48 PMDo I take it from your question that you're not seeing the same thing, Tarbat?
I don't use the network much, so no, I haven't seen this.  They look like approach speeds, so maybe aircraft transmitting inaccurate positions, and then timing-out on the local users RB.
#318
Nope, they aren't timed out, and stopping/restarting the network doesn't work for me - they are almost certainly "live" contacts - and I saw it happen live on MyFlights with a Jet2 B733 at Blackpool an hour or so ago.
EDIT And anyway, most of the aircraft would have stalled flying at those speeds at those altitudes!
malc41
15 Miles East of EGNJ
Canonjohns40D
Hi all
Re Rod's issue, I noticed this yesterday. I had a few aircraft showing over Aldergrove but they had heights speeds inconsistent with an approach? They were or appeared to be live contacts not network. However having used zoom to clear a couple of trail only aircraft these others disappeared?? Related issue perhaps?
John
Malc - I don't think it can be a wrong QFE or QNH - I had 1028 set, it's currently 1027 at EGLL - and anyway, the aircraft are showing very different altitudes from each other. Are you not getting this problem?
John Racars
Quote from: John Racars on June 21, 2009, 09:44:43 AM
but after a quick view it looks better.
Hi All,
I have to take back that.
My 24h SQL-report based on "MyLOG.db3" of yesterday gives a total of started flights in my area of reception of 6446. Very distorted I think. There are very much duplicated flights in this report (some flights even more than that).
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Would be interesting to see your log John.  Are the duplicates for aircraft showing FlightIDs, or for aircraft without FlightIDs?
I've just checked my report for today so far, and even with a timeout of 10 minutes, I'm seeing very few duplicates.
colinhall
Tarbat, have just downloaded 3.0. I dont have any airport outlines. How do I get them on please. Colin.
EMA
Quote from: RodBearden on June 22, 2009, 04:35:13 PM
Just switched on the network flights and I have TCX211L at FL295 over EGNX going absolutley nowhere and it is shown as networked and in the cruise.
EGNXR
Quote from: tarbat on June 22, 2009, 02:47:21 PM
Quote from: EGNXR on June 22, 2009, 02:22:06 PMThere seems to be a little gremlin in reporter today. See Attatched Screenshot:-(
Are you referring to 4007FF?  If so, then the aircraft set FlightID JCB2 at 8:01:34, change to a different FlightID BCY158C at 08:18:14, and then changed back to JCB2 at 08:18:17.  It then probably went out of range, and re-appeared after timeout as FlightID JCB2 at 08:27:39.
Looks correct to me.  Although the BCY158C flightID looks a bit strange, so may have been a false reception.  EDIT: In fact BCY158C was being used by 4007FD, so a false reception ( http://www.live-civil-mode-s.eu/search/popup.php?zoekstring=4007FD ).
What are your timeout settings?
Hi Tarbat,
Timeout set at 110/780 as per your previous suggestion. I just thought it very strange for JCB to be showing Cityjet callsign and route info. It seems strange the hex codes are so close as well for the aircraft involved.
Cheers John
Based in Derby 5Nm NW of EGNX
#327
Quote from: EMA on June 22, 2009, 05:54:32 PMJust switched on the network flights and I have TCX211L at FL295 over EGNX going absolutley nowhere and it is shown as networked and in the cruise.
This will happen if the local Radarbox receiving the aircraft has a long timeout setting.  This happened in v2.0 as well - I reported many months ago aircraft "hovering" at Aberdeen, and established that the local Radarbox had very long timeouts set.
Airnav, this really needs fixing.  The local timeout settings shouldn't affect how long an aircraft is shared on the network.
Quote from: EGNXR on June 22, 2009, 05:54:58 PMI just thought it very strange for JCB to be showing Cityjet callsign and route info. It seems strange the hex codes are so close as well for the aircraft involved.
Difference between the ModeS codes (4007FF & 4007FD) is just 1 bit - so probably a transmission/reception error.
EMA
Thanks Tarbat, I have never noticed this before but like you don't use the network that often.
EMA
TCX613L was tracked by Myflights landing at EGNX 10 mins ago and it is now showing networked at FL265 over EGNX.
I think I will switch the network off again :-)
