RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 18, 2009, 08:36:32 PM
This is a bug in V3.0 for flights that send position from ground. We are checking it right now.
HadNav
Alerts don't work properly. I have set up to raise a 5nm range alert. I may get the first one but not any others. If I revert to 2.10, I get my usual number of in range alerts, approx 30 or more in 12 hours.
We are already aware of the alerts bug.
John Racars
#348
Quote from: tarbat on June 22, 2009, 08:01:47 PMThis is the SQL I use for my daily report:
SELECT DISTINCT Aircraft.Registration AS "Reg"
Flights.Callsign AS "Flight ID"
Flights.Route AS "Route"
Aircraft.AircraftTypeSmall AS "ICAO Type"
Aircraft.Airline AS "Airline"
Aircraft.AircraftTypeLong AS "Aircraft"
substr(Flights.EndTime,1,16) AS "Flight Ended"
Flights.StartAltitude AS "Start Alt"
Flights.EndAltitude AS "End Alt"
Flights.MsgCount AS "Count"
Aircraft.ModeS AS "Mode S"
FROM Aircraft LEFT OUTER JOIN Flights ON (Aircraft.ModeS=Flights.ModeS)
WHERE ((date('now','-1 day') = substr(Aircraft.LastTime,1,4)||"-"||substr(Aircraft.LastTime,6,2)||"-"||substr(Aircraft.LastTime,9,2)) AND (Flights.StartTime IS NULL)) OR ((date('now','-1 day') = substr(Flights.EndTime,1,4)||"-"||substr(Flights.EndTime,6,2)||"-"||substr(Flights.EndTime,9,2))) OR ((date('now','-1 day') = substr(Flights.StartTime,1,4)||"-"||substr(Flights.StartTime,6,2)||"-"||substr(Flights.StartTime,9,2)))
ORDER BY Aircraft.Registration,Flights.EndTime,Aircraft.ModeS
Hi Tarbat,
I just tried this SQL.
Information: "Invalid token "Fllights" at position 1 of line 2."
SQL Error: near "Flights": syntax error
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
EGNXR
#349
Hi All,
I just lost all my local traffic off the map and can't get it back. Just been to make a coffee and returned to the shot below. Any ideas?
John
edit :- Just rebooted RB and its all good again:-) Very Strange!
Based in Derby 5Nm NW of EGNX
malc41
Have you tried zooming in then zooming out again on the map?
15 Miles East of EGNJ
EGNXR
Quote from: malc41 on June 23, 2009, 02:06:47 PM
Hi Malc41,
Yes zooming in and out had no effect, tried unchecking myflights on/off, removed filter settings and put back on. Had to reboot RB to get it back,
Cheers John
fatkat
ok a  little niggle about v3
if you have polar plot on the map and take a screen shot .....on the subsequent image file the polar plot is missing ....
apologies in advance if everyone else has mentioned this .
malc41
fatkat
rather its mentioned a couple of time, than get missed completely.
As the list grows its hard to keep track of what has been mentioned, maybe we could have a recap of niggles/problems Airnav?
marcdeklerk
Yes, please give us a list of the reported problems, and future options
fatkat
yes each new user is going to find the same "faults " and report them ....
perhaps a list in a "sticky"  that people can refferer to ..with solutions if available  ...though I can understand any reluctance as it clearly shows problems to prospective purchasers and the other side !
This is a beta so issues are expected otherwise it would not be a beta.
We will put an updated list up later.
fatkat
sorry ...it was not a criticism   just a suggestion etc
while I'm at it ......
changing the colour of the active track on the selected a/c - happens on the map ok  but not in the height plot ....[didn't notice what happened in v2 ]
any suggestions?
malc41
Thanks Airnav
It will help us all and hopefully stop some re-posting of what has already been said
DeeJay
Thanks Airnav for the 3.0,appreciate that it is a Beta, so playing all by ear for the moment, but I agree with some of the comments about fixes/intersections. They do seem to be too numerous, and possibly a mod to be able to differentiate between what I call ''master'' and ''sub-fixes'' might help. Regards
