Author Topic: RELEASED - AirNav RadarBox 2009 - 3.0 Beta  (Read 368319 times)
Manuel Mendes
    • Manuel Brito Photography
Re: RELEASED - AirNav RadarBox 2009 - 3.0 Beta
« Reply #360 on: June 23, 2009, 05:45:35 PM »
In relation to the fixes, I think we don't need those related to the DME distances.
ACW367
« Reply #361 on: June 23, 2009, 07:38:34 PM »
Airnav, A tiny one for you, a spelling mistake in the help menus. On the Maps Toolbars help page you have the following:
Resize
1- Hold down your right mouse button
2- Move your move to resize the map as desired
It should of course read move your mouse
hungryasthesea
« Reply #362 on: June 23, 2009, 08:00:28 PM »
I lost all data sometime this afternoon as well while I was out.
My Log shows data until 13:48:37 today in the last time field.
When I came back in, my flights was totally blank and had to restart Radarbox. Once I did this, MY log started populating again.
Hungryasthesea
f6gsg
  • Electa L12
« Reply #363 on: June 23, 2009, 08:11:14 PM »
Perhaps me and not a bug...
i would like to change the Home name by my call (F6GSG),
in the preferences windows, in the Custom Legend List
i display:
F6GSG,43.7011,3.8468
That is my call and the exact position (available in Home Data panel),
(south of France).
And Nothing ... no display ? (and Home is well switch off)
i try another data, also nothing,
What's wrong ?
in my opinion, it will be better to have for separator the ; caracter  as the ,
to be compatible with the Home data Longitude/latitude coordonate).
F6GSG
« Reply #364 on: June 23, 2009, 08:39:36 PM »
Works for me.  Are you sure you have entered the correct position in decimal degrees?
« Last Edit: June 23, 2009, 08:44:07 PM by Allocator »
    • Rod's RadarBox Downloads
« Reply #365 on: June 23, 2009, 08:54:53 PM »
And have you turned on Map...Custom Legends?
« Reply #366 on: June 23, 2009, 08:56:55 PM »
I bet that's it :-)  I'm sure that this is on by default, but that would do the trick!
« Reply #367 on: June 23, 2009, 09:08:50 PM »
Here is an update. These bugs have been confirmed (replicate them). If you think we have missed something important please give us a gentle nudge, there are lot of posts so its likely we have missed something.
Serious:
Some machines software does not start
Aircraft on map disappearing and returning with zoom
High:
359-000 degrees the vector of an airplane changes a direction for 180 degrees!
Timeout issues on the network causing aircraft to stay there for ages
Full screen and then return does not show map/aircraft
Duplicate Entries of flights in MyLog, required longer timeout or capabilty for user to change timeout
Check route alogrtithm and sometimes wrong routes are being displayed
Range alerts not working
Low
Company combo box not working
Font issue with commas and dots in custom legend
Filter to last ten minutes or one hour in MyLog Missing
No icon to resize interface window shown
Entries of closed maps in windows menu
Error message in preference menu
The 'execute a file' box is always ticked in alerts
text showing the aircraft details to the right of the photo of the aircraft is getting clipped
No up and down icons for Flights
Also the Vista64bit drivers and Too many fixes are being looked at.
John Racars
« Reply #368 on: June 23, 2009, 09:11:55 PM »
Hi Rod,
I did do so. In the Custom Legend List I write:  John Racars,52.3392,5.1924
Nothing happens on the map....
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
« Reply #369 on: June 23, 2009, 09:15:06 PM »
John and F6GSG - Can you check in Control Panel, Regional/International settings, that you have the period (full stop) as the decimal separator, and not a comma?
John - I just copied and pasted your legend entry direct into my system, and it displayed correctly - so you have done it right :-)
« Last Edit: June 23, 2009, 09:18:27 PM by RodBearden »
bailey_uk
« Reply #370 on: June 23, 2009, 09:19:05 PM »
My map colour scheme that ive exported and saved never seems to load up by default, even though its always the one thats used each time the programe is closed?
James
« Reply #371 on: June 23, 2009, 09:19:42 PM »
John,
Also check the color you have set in preferences for "Line of Sight" as this is also the color of the custom legends.
« Reply #372 on: June 23, 2009, 09:20:27 PM »
James - I have that trouble too - a workround is to rename your default scheme as Real Radar - that is the scheme that it seems to want to keep going back to.
John Racars
« Reply #373 on: June 23, 2009, 09:26:09 PM »
Hi Rod,
You are genius! After doing as you recommanded  it is working with me!  Thank you for the help.
13 NM East of EHAM
ANRB:
bailey_uk
« Reply #374 on: June 23, 2009, 09:29:15 PM »
Ok Rod I'll try that - which will overwrite the Real Radar colours? (No big deal) Edit, ive just renamed that one Real Radar2 whilst I was at it.
I tried renaming it default.mcl a few days ago but with no change so hoping this will solve it, thanks.
James
