Author Topic: Double Photo File  (Read 4690 times)
lambertw
Double Photo File
« on: June 20, 2009, 09:58:34 AM »
In data, photo folder why does it create a compatibility file with the same photos being download,the folder has stopped at 5627 photos and now the compatibility file is counting up with sometimes the same photos,is this normal I am running windows vista.
« Last Edit: June 20, 2009, 10:06:58 AM by lambertw »
Re: Double Photo File
« Reply #1 on: June 20, 2009, 10:21:09 AM »
What's a "compatibility file"?  I've only got one photo folder.  Running Vista also.  Did you install in the default folder, or did you follow the Vista FAQ and install elsewhere?
http://www.airnavsystems.com/forum/index.php?topic=1570.0
lambertw
« Reply #2 on: June 20, 2009, 10:53:33 AM »
Not being a computer wiz I cannot remember.
Fenris
« Reply #3 on: June 20, 2009, 11:03:38 AM »
You have it installed in Program Files, it is recommended not to do this with Vista because it avoids Vista's tendency to dislike files changing in the Program Files hierarchy, the so called virtual store.
« Reply #4 on: June 20, 2009, 11:06:23 AM »
I can't see the problem.  You've only got one photo folder, and each aircraft has two photos, which is how Radarbox should perform.  Here's mine:
I have no idea what "Compatibility Files" are.  Maybe because you've installed RB in Program Files, which isn't really recommended.
EDIT:  See http://forums.techguy.org/windows-vista-7/556762-compatibility-files.html - it's caused by installing in Program Files.
« Last Edit: June 20, 2009, 11:10:50 AM by tarbat »
lambertw
« Reply #5 on: June 20, 2009, 11:21:38 AM »
Tarbat, it's not a problem,in that arnb works fine,it was just an observation that I thought was not as it should be.I think that fenris and yourself has the answer.Thank you all.
EMA
« Reply #6 on: June 20, 2009, 11:27:28 AM »
Its the Virtual Store Redirection feature, install the program as per the FAQ's and you should be okay.
lambertw
« Reply #7 on: June 20, 2009, 01:29:20 PM »
Thank you all for your help.
