Merge Database
Started by Spaice, June 23, 2009, 08:03:09 AM
Spaice
I need youre advice on the best way to merge the databases, I have around 7,000 records in the RB v2 software and now that I have installed RB V3 in a seperate folder I have around 1700 records on V3.  What is the best way to combine the database from version 2 into version 3?
Stephen
Stephen,
There isn't really an easy was of merging the databases.  You can copy the following 2 files from your old installation to the new one if you wish:
NavData.db3 - this is your source database of aircraft information
MyLog.db3 - this is the historic record of the aircraft you have picked up in the past.
Spaice
Thanks Allocator, if I copy the files across from RB V2 this would overwrite the information allready gathered in  RB V, allthough thats not a great deal at themoment and I guess I would soon pick most of them up again anyway.
REgards
Stephen
jgrloit
An set of Export and Import via CSV files would make a lot of sense.
It would also enable users to sort the table during the reload process, and do batch edits on the CSV files - to correct known errors on Shortform of Aircraft type - etc.
Based in Hexham - Tyne Valley
Spaice
Perhaps this could go on the wish list for the the next version, this would make it a simple process.
