No map
Started by carp777, June 26, 2009, 05:22:11 AM
carp777
can someone please help ! i am not getting any picture in the box where the map should be.every thing else seems fine my flights showing o k with picture of aircraft but no map to see any aircraft hope some one can help proberbly pressed something i should not have
What happens when you shut down RB and restart it, do you still have no map?
Do you have a blank map, or is there no map at all?
carp777
yes after shutdown and restart there is still no map. there is no map at all just a grey square were map should be. thanks for quick reply Allocator
I'm not running RB at the moment, so working from memory - what happens when you use Map > Open > Default?
carp777
Tried another restart and got this warning message. File C\Program Files\AirN
avSystems\AirNavRadarBox2009\Map\Default.ml3 does not exist        thanks for any help        Bryn
OK, so use Map > Load and load one of the other map locations that come with the standard install - or use Map > New and pick a new location.
carp777
I am not very computer minded so where do i get map>Load from
    cheers BRYN
The list of menu option at the top left of the RB window - it says File Filters Map etc
Left click on Map
Click on Open/Save
Open any of the maps you see listed
When the map opens, zoom out so you can see a wider area and scroll the map to your home area - or click the Home button on the menu bar if you have set your home position.
Zoom in as required.
carp777
Tried that got as far as Click on Open/save but no maps listed
Bryn
OK, try 'Set Map to..' in the Map menu.
I've got to  go to work now, so I leave you in the capable hands of the other forum members - somebody with RB running in front of them will be better than me working from memory :-)
carp777
Thanks for your help Allocator
      Bryn
EMA
Go to the Map menu and try set map to United Kingdom.
carp777
tried to open set map to but it wont open
     thanks for your reply EMA
   Bryn
EMA
If you use Windows Explorer can you go the the Map directory and see if there are any files in there?
Right click on start menu to bring up explorer
