Part 2 - RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 28, 2009, 11:51:54 AM
slipdog
The list looks very promising.
@Terre
I couldn't see anything on that page regarding airport filtering problems
swadeep
Hi. I read before that, if using vista 64bit, i can use EASYBCD to allow unsigned driver to work and so i did and while installing driver, it just says it found the driver but encountered problem installing it (code 39).
Can someone help me please or point me in the right direction?
Thanks so much.
Swadeep
We are getting very close to a long way of certificating our driver with Microsoft. We hope to have all this ready in 2 weeks.
Terre
@ Rich (Slipdog)
It's the second post of AirNav that contains the list of all Improvements/Suggestions. Use this link: http://www.airnavsystems.com/forum/index.php?topic=2958.msg26977#msg26977
regards, Terre
swadeep
Quote from: AirNav Development on July 16, 2009, 12:54:53 AM
Two weeks!!! That's so long and far away. Every min that is passing by I am losing out on the free 1 Year network subscription. Oh well. Thanks for you answer airnav. Will wait longer. Please make it happen soon :) Thanks
You can start Vista 64bit without requiring signed drivers by:
Restart your machine. Press F8 when windows begins to load and choose the Windows Vista—"Disable Driver Signature Enforcement"
Option, then install the drivers and it should work fine.
GlynH
What about an enhancement to SmartView to allow inputting of Mode-S details along with Callsigns?
I have copied & pasted all of the Registrations I have in Alerts into SmartView and it is very handy to hear an Alert and quickly glance at the SmartView tab to see if it is being picked up as was the case with G-VLCN - this afternoon.
In Alerts I also use wildcarded 43C* and AE* / AD* to alert me to RAF & USAF aircraft and it would be good to see them listed in SmartView because most of them don't appear on the map due to no ADS-B positioning information so the ability to quickly view any pertinent information on the target would be a good thing.
Would anybody else find this a handy feature to have?
Hopefully one for the list Terre!
Thanks & regards,
-=Glyn=-
Terre
Looks as if I'll have to update and expand the list and the poll soon...
radarphil
There is no full version yet. We will be releasing patch 1 of the beta soon to the public.
Depending on its sucess we will release the full version.
ch33se
Anyone else experiencing the map not loading on startup?. Ive had to go back to version 2 as the map will not load after 2 startups.?
Ch33sey
GlynH
A very small change that I would like to see around the emailing of Logs...
When the email arrives it is from the Users Name.
However when I receive an email from the Alert feature it is from RadarBox 2009 whatever-version-you-are-running
For me anyway I would like to standardise the sending email address to be constant and be listed as the program name instead of the user name.
When I look for emails from RB it does not register that I should also be looking for emails from myself!
Maybe change this to show the same sending email address as Alerts or make it configurable?
The reason I ask is because I have various automated tasks running here and on remote sites from which I receive updates/warnings/status emails etc. and without exception I am able to configure the sending address to make it easy to determine at a glance where the email is from and simplify setting up Rules to deal with them.
A minor change I know but it would work well for me - anyone?
Thanks & regards,
-=Glyn=-
malc41
ch33e
I have had problems with the map since v2.
I usually find if I select another map and then select back to home it works.
I thought origionally it was my video card on my laptop, but seems not?
15 Miles East of EGNJ
Fenris
Quote from: AirNav Development on July 15, 2009, 04:56:49 PM
We will release Patch 2 in 2 to 5 days. We are just awaiting for the answer of 2 beta testers on some pending items.
Any update on this folks? It's past the end of that window and it's gone a bit quiet again....
GlynH
When it goes quiet that is usually a good sign...just around the corner! ;^)
Kind regards,
-=Glyn=-
