Part 2 - RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 28, 2009, 11:51:54 AM
Part 2 of AirNav RadarBox 2009 - 3.0 Beta discussion.
We have created a new topic to continue the discussion on V3.0 Beta.
Only problem reports will be accepted on this new topic.
As a reminder, below V3.0 changes/new features and download links.
RadarBox is the only receiver with an integrated worldwide ADS-B network and with a huge set of features inside a single application without the need of installing 3rd party addons. AirNav RadarBox 2009 - V3.00 is by far the most complete, sophisticated, reliable and accurate ADS-B decoding software ever released.
As usual work never stops at AirNav Systems. We are already developing the brand new "AirNav FlightWatch" application to be released later this year. This will be focused on the professional market but with an enthusiast version also available. It is the only software able to track flights using an worldwide data source network: FAA Radar System, ADS-B, RadarBox Unit, ACARS and Flight Plan information.
Full Download:
http://www.airnavsystems.com/download/anrb/ANRB30BetaSetup.exe
Upgrade from V2.0 to V3.0 Beta:
http://www.airnavsystems.com/download/anrb/ANRBUpgrade20to30Beta.exe
Official full list of suggestions/improvements:
- 20% more flight IDs received: decoding of more mode-s protocol frames;
- Tracking of aircraft sending ADS-B information on ground;
- Possibility of writing custom labels on map;
- Optional retrieval of flight information data from online database;
- Flights without callsign information added to MyLog;
- New/Updated AIRAC cycle: more than 100 thousand updated aviation database (airport, runway, VOR, NDB);
- Ability to zoom in closer. Hi-Res airport outlines / track aircraft in taxiways;
- Possibility of auto populating aircraft information without downloading photos;
- Improved Algorithm for the transition of network flights to live (and live to network);
- Corrected problem with Slow Menus on certain machines;
- 1698 Airline Logos (many of them reviewed);
- 404 Country/Military Flags;
- UK/Ireland Time on status bar now shown correctly;
- Choose to show/hide Home position on map;
- Alerts/Reports email reports now sent from central server;
- Improve user awareness of incompatibility with AVG Anti-Virus (easy to add exception);
- More application data being worked inside threads: application runs faster;
- Preferences box now fits different screen resolutions;
- FTP Upload status information on status panel;
- "Purple rain/invalid positions" problem corrected;
- Improved Logo decoding routine: fully compatible with ICAO, IATA, Military and private jet flight codes;
- Option to show/hide Home Legend
- Registration/multiple alerts now working correctly;
- Weather List clearing problem corrected;
- Aviation Signs in Menu status updated;
- Email Alerts at consecutive days problem corrected;
- Duplicates in the Reporter bug corrected;
- Remember of Last Color Used;
- Up/Down arrows to show Vertical Rate on maps;
To all the team involved, especially the dedicated beta-testers a huge thank you!
marcdeklerk
Thanks airnav , however when can we expect update patch 1?
We have about 20 problems reported. The 3 major ones are now corrected.
The remaining are easier to correct and we will be working on them during the next 3 days. After that we plan to send the .exe to the user that reported some of those problems - once we get a green light from all of them we will have the new .exe available to the public.
We want to have some good news by July 2nd.
jgrloit
Can I suggest that a date for the .EXE be added to the download links above, along with any patch Version detail - patch1    for instance, so users can see if there is a newer version of the Beta.
Thanks.
Updated for reply below:-
I was thinking of the Public Beta and it's build date - NOT all the restricted pool Beta versions!!!
Based in Hexham - Tyne Valley
Jgrloit: we would do that but since there are external factors that do not depend on us (pre-testing done by users that complained) we can't. We want to send the new .exe to those users this Tuesday - we will keep this thread informed on what's going on.
ACW367
Development
A very minor bug, on the myflights list you have the red outline to show which square your cursor is on.  If you have a flight that doesn't autopopulate for example if you are not connected to internet. On the blank line in the myflights list the red cursor outline disappears on the empty silhouette column.  It appears in all other columns and on silhouettes of populated aircraft.
waddington1
Hi I originally reported that V3 works faster for, which it does, but after the program has been running for a short time the menus stop working.
malc41
15 Miles East of EGNJ
atcukmatty
I do not know if this is possible but when you click a spot and drag the courser and instead of moving the map it shows the bearing and a line from where you clicked to the current mouse position (like a real radar at ATC would)?
atcukmatty
why is it when i uninstall v2 and download and install beta v3 it does not run.
It is running in processes but the software is not running?
abrad41
Strange, there is a bug with Xp, but I thought vista was ok
Quote from: atcukmatty on June 29, 2009, 06:54:55 PM
How long have to left the software loading before giving up?  The new install seems to take a while to check all the files on first run.
Also, there was no need to unistall your previous version of RB, as V3.0 Beta installs into a totally separate directory - although with Vista, I'm not too sure what it does!
Glad I skipped the whole Vista thing!
