Part 2 - RELEASED - AirNav RadarBox 2009 - 3.0 Beta
Started by AirNav Development, June 28, 2009, 11:51:54 AM
billmurphy
Version 2.00 still runs fine, i didnt know there was a version 2.1, but as stated version 2.0 runs fine, di need to uninstall version 2.0    im afraid if un-install version 2.0 and then cant get version 3.0 to run
Thanks Billy
radarspotter10
hi all
i have a   Mode S  Flight   Route           Regist  Airc  Airline              Date and Time
  43C219  AAC555                   ZA766   ...   UK - Army            2009/06/30 19:43:06
my picture show a army helicopter, but when i click on photo it shows a  Picture of the Cessna 421B Golden Eagle aircraft-----------------airliner.net not right.
from pat
OK Billy - I think that V2.1 and 2.0 were the same, but one came on CD with a new RB and the other was downloaded - can't remember now :-)
I'm not too sure what your problem might be.
billmurphy
Yeah i downloaded my current version a while ago   I have been using RB for just over a year now, i find it brilliant. Maybe some else comes across the same problem as more people download the newer version and maybe a fix can be found, but in the meantime i can still enjoy the current version.
Thanks for you help and replies anyway.
Regards   BILLY
I noticed a further strange thing:
Under preferences I unchecked the "Auto-Populate Aircraft Data" feature, but kept the "download photo" feature aktive. After that, I manually changed the false entry of the SIA 9V-SKH A380 in the "NavData" Database. Then I have manually corrected the MyLog entry of the mentioned aircraft. Finally I removed the downloaded 9V-SKH pictures of the "stored" B744 AC from the photo directory.
And now it comes: Today, after tracking the 9V-SKH in flight, the MyLog entry was changed back to the false B744 data, while the NavData DB entry is still correct. Is it possible, that the "Photo download" feature is somehow messing with the MyLog entries?
Is this a known problem?
Let's see what happens if I don't delete the pictures of the earlier B744 9V-SKH.
billmurphy,
Right click on the RadarBox Beta version icon and select proprties then compabilty mode and select run as windows 98/Me.
MyLog is a historic record of what you have picked up using your antenna.  If you have changed the details of 9V-SKH using DataBase Explorer, this will not affect waht you see in MyLog for past contacts, but it should correct it for new contacts.
As far as I'm aware, all my A380's have autopopulated correctly without any manual edits.
#38
Quote from: neroon79 on June 30, 2009, 07:28:57 PM
OK, I'm with you now :-)
I checked 9V-SKH using Database Explorer and it showed the incorrect details for the B747, so this is what I did:
- Manual update using DataBase Exploer putting in the correct details for 9V-SKH
- Deleted the photo link details in DataBase Explorer too in case these were wrong too.
- Opened MyLog and searched for 9V-SKH - wrong details displayed.
- Deleted the wrong details in MyLog by clicking on the fields and selecting delete
- Used MyLog Populate and the correct details are now entered automatically into the blank record fields for 9V-SKH.
Allocator,
The 9V-SKH is missing in your list. Try out to find the 9V-SKH in your MyLog.  your At first the 9V-SKH was tracked as B744 of an unknown Airline. I manually changed it at all positions. Especially in the MyLog Database.
Screenshot of my tracked A380 AC:
But after downloading the two AC images it changed back to the B744 Data.
billmurphy
Airnav support
Run version 3 in compatability mode (98/me) and its working fine.
Thanks for your support    WELL DONE
Regards BILLY
abrad41
billmurphy
I think there is a fix being sorted for this problem, should be fixed in the next beta edition, so you won't have to wait to long.
Andy
Quote from: Allocator on June 30, 2009, 07:55:15 PM
Well, we did the same. But after tracking the 9V-SKH again (with activated photo download feature) , the false B744 data is back again. But only in MyLog. This time I leave the false 9V-SKH pictures where they are and see what happens now...
Hopefully the SKH is servicing the late SIA flight from LHR to SIN later this evening (night).
I find out about the 9V-SKH problem by using this site: http://plane.spottingworld.com/A380_production_list
According to this list the SKH was delivered before the SKG. Futher i was wayting for SIA318 but somehow it didn't occur. I got suspicious and did some
recherche. The rest is history.
#43
Quote from: neroon79 on June 30, 2009, 08:03:50 PM
Allocator,
Changing the details for 9V-SKH in MyLog will NOT change the details when you pick the aircraft up again in the wrong details are still in NavData.db3 which is edited using File > DataBase Explorer.  Look again at my 2 posts and the 2 MyLog screen shots.  Read carefully how I fixed this.
Edit:  OK read you posts thanks.
You will also need to delete the 2 incorrect 9V-SKH photos in the /Photos directory, as they won't be overwritten by autopoulate and you will be stuck with the old pictures.  These are:
abrad41
neroon79/Allocater
Just looked in my Navdata file and mylog file - I am showing the correct details for 9V-SKH in both of them, the only thing which is wrong is the photo link, this to the B744.
Andy
