All myflights ADS-B seem to have gone?
Started by ch33se, July 01, 2009, 06:19:24 PM
ch33se
Hi There
Newbie here still experimenting, but i was building a lovely polar diagram when i left for work this morning and picking up lots of early morning flights, however on coming home this afternoon nothing at all showing, not one flight even though they are overhead.
Ive checked the aerial connections and the box is flickering away merrily.
Is it the weather??
Im using the beta 3 software and have my aerial in the loft which yesterday and this morning was showing some good results.
I live in Glossop near Manchester and get most of the 23 traffic flying more or less directly over me.
Bri W
Bri w
What happens if you shut down the RadarBox software and restart it?  Do the flights in MyLog reappear?
What light indications are you getting on the RadarBox hardware receiver?
ch33se
Hi There
Have tried closing down and restarting all lights flickering for usb and msgs, last message received in Mylog GNIKO stating it is ADSB equipped at 1859{this a/c based at Man} but no display on the map of anything, ive had a few 757 and A320 which are equipped and flying with in eyesight for about 5 mins and no display on screen.
So Mylog seems to be logging and im getting information on flights showing in Myflights.
Hardware showing connected and occasional msgs coming through, not moved set up since yesterday when i was rcving A/C flying directly overhead at to about 1500ft at Man.
Could it be a prob with Software beta?
If i network i get all the network flights displaying.
Bri W
Spaice
Have you set any filters, say to show only flight from a certain airport or route, click on show all and clear any filters, you may have done this by accident.
Marpleman
Hi Bri
I'm in Marple, so only about 4 or 5 miles away - to be honest i'm not picking up much into EGCC on 23 myself tonight either, currently only showing approx a dozen flights in "My flights" which is very low for this time of the evening?
I'm picking up the easyjet/domestic traffic en route to Scotland fine though.
As I type this,it's just jumped to 30 + flights however, which appears about normal time-wise
Keep us posted
Rich
Marpleman
Bri
Can you see G-EOMA andG-FDZE - both on my screen full ADS-B on approach to EGCC right now?(time 20:20) - the former should be overhead your position?
Rich
ch33se
Nope ive just watched EOMA fly over me and then a long lazy turn onto finals but nothing on the map it was displaing in my flights as OJMR which has just gone over but nothing on screen...............:}
Bri
Marpleman
Actually had both EOMA and OJMR on finals about 5 mins apart, separated by the Thompson 737 - all three fully tracked
Rich
ch33se
Hmmmm
Like i say left for work at 5 this morning and it was displaying allsorts of wonderful traffic, but on arrival home this afternnon not a sausage, im only showing 2 Ei flights in myfligts at the mo and of course no display on screen.
Shall have to go and battle the heat in the loft and have a fiddle with set up and connections.
Bri
Quote from: ch33se on July 01, 2009, 07:42:05 PM
Hmmmm
Bri
Are you using the standard antenna with the standard length cable?
EGNXR
Hi all,
Seem to have had a similar problem Flights showing on screen slowly dwindling off. I took a screenshot of what I was seeing. (88 in Myflights) not many on screen.
Shutdown and reebooted RB and (52 in Myflights) but a lot more showing on screen.
First pic 8pm second pic 8:03pm
John
Based in Derby 5Nm NW of EGNX
EGNXR
Sorry last post would not let me send both pics
John
Could be the bug in v3 beta with aircraft dissapearing from the map.  Try zooming in and out and see if the aircraft re-appear.
Or just left click on the map and drag it a tiny amount.
EGNXR
Tarbat,
Tried the zooming in and out it had no effect that is what prompted me to take the screen shots.
John
