I see nothing
Started by vassylad, July 06, 2009, 09:59:13 PM
vassylad
Hi guys I am seeing nothing whatsoever on my screen this evening no live or network traffic and both boxes are yellow at the bottom right hand side of the screen and the process hardware flights box is ticked.
TIA
Mike Vass
vassylad
Just adding on to previous post, when I open RB instead of the map and Aircraft/Airline etc opening up I get the activate alerts for network flights open up instead
Michael
Quote from: vassylad on July 06, 2009, 09:59:13 PM
TIA
Mike Vass
Have you tried shutting down your PC and restarting it?
I don't suppose that you have updated your Firewall software and prevented the software from communicating with your RadarBox - or have you plugged the USB lead into a different USB socket?
Two yellow 'lights' would indicate that the software can't 'see' your RadarBox.
What are the lights on you RadarBox doing?
vassylad
Hi I have unplugged everything, firewall is on but it always is, the only light that is on is the power light and nothing else, when I restart RB no lights flash which is worrying any ideas guys please..
Michael
EMA
Try replacing the usb cable.
If you plug the Airnav box in when the PC is on does it say new hardware found?
fatkat
also check your aerial  connections [if its got un hooked then your not likely to get any signals]
EMA
Check the centre connector on the aerial lead has not pushed back in to the cable.
