Author Topic: Minor Bugs  (Read 25036 times)
    • Rod's RadarBox Downloads
Minor Bugs
« on: July 06, 2009, 11:22:04 PM »
Just to register that with Patch 1 2009/07/04 15:52, I'm not getting the resizing mouse pointer between the map and the grid, but I can still resize the panes.
EMA
Re: Minor Bugs
« Reply #1 on: July 07, 2009, 06:44:42 AM »
I am not really sure what ANRB version we are currently using is it the same for all of us or do we all have specific executables to fix certain issues?
Re: Minor Bugs
« Reply #2 on: July 07, 2009, 07:56:53 AM »
My guess is that we're testing different versions.  I'm testing a version Andre emailed me on 5th July to test port 30003 output.  Is anyone else testing port 30003 output - I'm not having much success.
EMA
Re: Minor Bugs
« Reply #3 on: July 07, 2009, 08:01:12 AM »
I think you are right mine was emailed from Andre at the end of June to test disappearing aircraft and network issues.
Re: Minor Bugs
« Reply #4 on: July 07, 2009, 09:18:01 AM »
Can't we tell by the date/time stamp on Help..About? That's why I quoted it.
Re: Minor Bugs
« Reply #5 on: July 07, 2009, 09:26:30 AM »
Okay, the version I'm testing is 2009/07/05 15:21 in Help--About.
TEST: Testing port 30003 output fully compatible with SBS-1 output.
FAULT: It has a broken port 30003 output, as all the ModeS hex codes are missing.  Reported to Airnav by email.
STATUS: Reverted to previous version 2009/06/18 20:52
Re: Minor Bugs
« Reply #6 on: July 07, 2009, 03:59:59 PM »
The help -> about doesn't always help as the install sometimes registers the time and date of the install there.
Tarbat roger, Development is working on it.
CAM
    • http://www.planedaft.co.uk
Re: Minor Bugs
« Reply #7 on: July 07, 2009, 09:10:44 PM »
Tarbat,
Does 30003 output work on 2009/06/18 20:52(which is the public beta I presume?), as i cannot see any output ?
Edit - User error !! can see output on 30003, but it does not seem to give output if ANRB has been running for a while - undefined period at the moment, just restarted and waited and output OK.
CAM
« Last Edit: July 07, 2009, 09:15:16 PM by CAM »
Re: Minor Bugs
« Reply #8 on: July 10, 2009, 08:00:29 PM »
Another bug - if you have a satellite image overlay and go to full screen map view, when you return to normal view, the satellite image disappears.
Re: Minor Bugs
« Reply #9 on: July 11, 2009, 11:16:29 AM »
I've noticed that on the Network grid, I'll click on an aircraft, there's the usual slight delay, and then, when RB attempts to centre that flight in the grid, the selection jumps up or down by one or two aircraft, so I'm looking at the wrong one.
This doesn't seem to happen on MyFlights, where it keeps the correct flight selected.
Or is it just me?
Re: Minor Bugs
« Reply #10 on: July 11, 2009, 11:17:40 AM »
I'm noticing that RB still will jump to the front unexpectedly while I'm doiing something else. Doesn't seem to be related to alerts.
EMA
Re: Minor Bugs
« Reply #11 on: July 11, 2009, 11:19:35 AM »
Not seeing that issue
Re: Minor Bugs
« Reply #12 on: July 11, 2009, 12:19:46 PM »
I've also never seen this happen.  Would suggest that this might be a PC setup issue.  Does it happen regularly/frequently - can you establish any pattern to it?  Do any other program windows ever jump to the front like this?
Re: Minor Bugs
« Reply #13 on: July 11, 2009, 12:31:18 PM »
No - it's only ever RB that jumps to the front, and I'm not accidentally hitting Alt-Tab when it happens. An alert has just popped up while I'm typing this, so it's not related directly to alerts. No other pattern has emerged yet, though.
Perhaps, as you say, it's something on my PC.
Re: Minor Bugs
« Reply #14 on: July 11, 2009, 12:35:48 PM »
Could it be that it pops up when there's a message to display in the status bar?  For example, network download, or ftp upload, or email send, etc.
