Author Topic: ftp time parameter  (Read 16600 times)
itestoo
    • Radarvirtuel
ftp time parameter
« on: July 13, 2009, 10:36:21 AM »
I would like to know if in future software we can decrease the time in ftp upload map ?
In switzerland they give in real time the air trafic with inercative map on plane
http://radar.zhaw.ch/radar.html
Some plane can be seen over French area. (Dijon)
Best regard's
Laurent
www.radarvirtuel.com
[attachment deleted by admin]
Harry
Re: ftp time parameter
« Reply #1 on: July 13, 2009, 10:58:32 AM »
May be another suggestion: user can self define the name of the output file.
Best regard's
Laurent
Brimon
« Reply #2 on: July 13, 2009, 11:39:30 AM »
Laurent,Would be great if we could get this kind of detailed map in RB.
« Last Edit: July 13, 2009, 11:41:18 AM by Brimon »
Chasing the heavies from a secret bunker in Scotland
« Reply #3 on: July 13, 2009, 11:45:51 AM »
Like this?
Brimon
« Reply #4 on: July 13, 2009, 11:51:12 AM »
tarbat,I hate you! ;)  is there anything you can't do on RB?
How did you do that?
« Reply #5 on: July 13, 2009, 12:38:44 PM »
1. Take any map image, and save it as a jpg in the RB Satellite folder.
2. Work out the map coordinates for the top left and bottom right corners, in degrees/minutes format.
3. Type those map co-ordinates into the attached spreadsheet.
4. Create a .stl file with the same name as the map file, containing the 4 numbers calculated in the spreadsheet.
5. Open the map as your sateliite layer in Radarbox.
Simples!!
Detailed explanation of the calculations at http://www.airnavsystems.com/forum/index.php?topic=1376.msg10356#msg10356
Brimon
« Reply #6 on: July 13, 2009, 01:40:55 PM »
Cheers tarbat.
ps. I don't really hate you lol!
Brimon
« Reply #7 on: July 13, 2009, 07:10:43 PM »
tarbat, what program do you use to save to .stl format?
« Reply #8 on: July 13, 2009, 07:16:07 PM »
Windows Notepad will do fine, just make sure the saved file has a .stl extension, not .stl.txt
Brimon
« Reply #9 on: July 13, 2009, 07:25:29 PM »
Cheers Allocator & tarbat works great!
Brimon
« Reply #10 on: July 13, 2009, 09:02:58 PM »
tarbat / Allocator,
With a little help from you guys & Google Earth Pro I got these.
Glasgow Airport: Matches up well to actual location of runway
And a more general overview of West Central Scotland,again pretty spot on
Well chuffed with these, thanks guys.
colinhall
« Reply #11 on: July 14, 2009, 05:57:17 AM »
Tarbat, morning, means your so good at this what is the "easy" detailed way of doing my home area please. This would be great to look at because of the fly overs from Europe and Asia way.Please I might say!! regards Colin.   my area is on my profile. please.
« Reply #12 on: July 14, 2009, 07:44:22 AM »
Well, you need a good map source first.  I've done a quick map centred on your area, but it's only a 1:250k map.  Just unzip the attached zip into your RB Satellite folder, and then open the dover image in RB.
Brimon
« Reply #13 on: July 14, 2009, 09:36:38 AM »
Colinhall.
here is a good resolution pic of your area.
http://i28.tinypic.com/bjbdiq.jpg
The figures you need for tarbat's stl file are
52 06'56.36N
 0 38'11.23W
50 19'15.36N
  1 49'19.01E
I can't get it to line up properly , I think becasue there is an East coordinate in it.Maybe tarbat can advise.
« Reply #14 on: July 14, 2009, 09:49:09 AM »
Spreadsheet copes with east coords okay.  Beware that the larger an area you cover, the line-up is less precise.  So use small areas.
You can see this with the standard satellite images.  It all depends what projection has been used for the map.  For example, if I do the whole of Scotland, I get alignment problems.
