Mode S
Started by lambertw, July 21, 2009, 09:20:55 AM
lambertw
Is it possible to filter out non ADS-B aircraft so that you can only see these on the information screen and not have the ADS-B aircraft showing.
nortonbeak
Quote from: lambertw on July 21, 2009, 09:20:55 AM
If you mean "not have the non-ADSB aircraft showing", then press the ADSB only button.
Quote from: nortonbeak on July 21, 2009, 09:26:48 AM
Excuse my ignorance but where is the ADSB only button located?
Bratters - it's above the grid - if you only have a narrow grid you may have to resize it as it may be being hidden by your map:
Quote from: RodBearden on July 21, 2009, 10:53:15 AM
And of course the button only appears on the MyFlights page as Network Flights are all ADS-B
Terre
You'll find the filter button 'ADSB only' in the quick filter section of 'MyFlights' in the Interface, just above the grid.
However, as you said you want to filter out non ADS-B aircraft, this quick filter will not work. You might want to follow Allocator's suggestion to activate a filter using "Latitude = 0", see his post:
http://www.airnavsystems.com/forum/index.php?topic=480.msg3595#msg3595
lambertw
Got it sorted now, thank you all.
malc41
This is a good point as how many people miss these buttons because the map covers them up?
15 Miles East of EGNJ
Jeremy
How do you bring that row of buttons to the front? The map window seems to be fixed.
J.
G4DOQ
QRZ.com
Quote from: Jeremy on July 21, 2009, 08:30:07 PM
J.
You can drag the divider between the map and the lists.  Just put your mouse pointer over the line and when it changes to a double headed arrow, hold the left mouse button down and drag left/right as required.
Jeremy
Found it but  it is a slow task when my cpu is so active. I do not have that button. The last one is Show All.
J.
G4DOQ
QRZ.com
Quote from: Jeremy on July 21, 2009, 08:45:36 PM
J.
The ADS-B Only button ONLY appears in the MyFlights tab, as ALL the aircraft in the Network tab ARE ADS-B.
Jeremy
Thank you. A fountain of all knowledge as always.
J.
G4DOQ
QRZ.com
Quote from: Allocator on July 21, 2009, 08:49:27 PMThe ADS-B Only button ONLY appears in the MyFlights tab, as ALL the aircraft in the Network tab ARE ADS-B.
I could swear I've read that somewhere else recently  :-)
