Author Topic: RELEASED - AirNav RadarBox 2009 - 3.01 Beta  (Read 182092 times)
snowman
Re: RELEASED - AirNav RadarBox 2009 - 3.01 Beta
« Reply #15 on: July 23, 2009, 05:34:09 PM »
Thanks for the latest update - have just downloaded and run but can't see how to get the Up/Down arrows, I'm still getting +/-
As answered in other threads, the up/down arrows change was abandoned.  See http://www.airnavsystems.com/forum/index.php?topic=2893.msg25950#msg25950
Then why is it still being listed in the suggestions/Improvements ? After a career spanning 30+ years in ATC I find it hard to get my head around the +/- rather than the up/down arrows. I live in hope ;)
afo47
« Reply #16 on: July 23, 2009, 05:59:31 PM »
all is ok with XP sp3 and also on Vista.
Jstars ok at least but no chance with BS alert
(it start and says : '' is not a valid integer value...something
on port 30003 is different that on sbs1 )
with telnet port 30003 is ok : MSG 1,3,4,5,6 here but
no air to air MSG7 and i have not seen MSG8.
Will try to compare with my sbs1 at the same time.
SBS/RB MilLog is OK also ...i can look
mil. acfts from my location (Frontera)
I have tried 2 versions of Squawkbox and nothing.
Now the program is becoming interesting
good job
JEAN
marcdeklerk
« Reply #17 on: July 23, 2009, 06:02:57 PM »
Thanks guys
Blincodave
« Reply #18 on: July 23, 2009, 06:13:17 PM »
My first post having 'watched' this forum before deciding to buy. Purchased my Radarbox yesterday and uploaded 3.01 today. Very impressed with this product. I have previously owned an SBS-1.
I'm running on XP and notice that although I've ticked just to autopopulate the aircraft data, I'm still receiving downloaded photos despite leaving this option unchecked.
Dave
« Reply #19 on: July 23, 2009, 06:24:12 PM »
Didn't bother with the patch but downloaded the full version. So far, everything working well on my Vista machine.
A big well done to all concerned.
sterigia
  • forza paris
« Reply #20 on: July 23, 2009, 06:34:19 PM »
i have to correct myself: network activity goes down to zero every now and then
frank
ciao.
frank
Squad 701
« Reply #21 on: July 23, 2009, 07:00:03 PM »
frank
Also the only thing I noticed, the Network dropping in and out.
Can't miss that one really :-)
Otherwise the ball is rolling in the right direction.
Cheers.
Blincodave
« Reply #22 on: July 23, 2009, 07:15:09 PM »
I've got the network dropping in and out as well.
Dave
« Reply #23 on: July 23, 2009, 07:16:48 PM »
It might be a server problem.  AirNav Support has acknowledged this issue on another thread.
lovemuscle
  • location stafford
« Reply #24 on: July 23, 2009, 07:29:32 PM »
Downloading as i type this,cheers all your fast i give you that,lets hope my alerts work now..gaz :)
« Reply #25 on: July 23, 2009, 07:35:00 PM »
Dave
The thumbnail pictures are downloaded and saved to your PC, so when you deselect the photo and autopopulate options, you still have those thumbnails available - as you will if you operate your RadarBox mobile without an Internet connection.
jgrloit
« Reply #26 on: July 23, 2009, 08:14:55 PM »
Polar diagram, with working lines as radials attached.!!
Based in Hexham - Tyne Valley
dl1812
« Reply #27 on: July 23, 2009, 08:24:34 PM »
Well Done AirNav - works for me ! - I'm using both Vista Home Premium and XP Pro.
I actually posted a comment about not being able to save colour changes, but I then discovered the "export" button - Dur !
A question - is there any way that I can save the altitude settings I normally use, to save changing them every time I open RB ?
Thanks in anticipation
Dave L
Terre
« Reply #28 on: July 23, 2009, 08:33:50 PM »
*jgrloit
Can you describe your problem as I dont see anything wrong on the screenshot.
jgrloit
« Reply #29 on: July 23, 2009, 08:38:49 PM »
The problem as mentioned in a previous message is that the Polar diagram still has a number of the radial "construction" lines, rather than those lines having been cleared out.
They only disappear if you turn the display of the polar off then back on!!!
Did not happen on the 3.00 beta.
Only noticable if you clear the polar right down and start again, as I have needed toas I have had the unit mobile between Newcastle, Eastbourne, Stranraer and back home to Hexham.
