RELEASED - AirNav RadarBox 2009 - 3.01 Beta
Started by AirNav Development, July 23, 2009, 12:18:24 PM
Terre
@dl1812
If you refer to the Elevation colors: they will get stored when doing an export, as will the complete colors that you have set. You call up a defined color set via the menu MAP > COLORS > 'yourcolorset' or via the toolbar. I suggest to name the exported colorset to something different then the presets, eg. "Newcolor3'.
Terre
#31
*jgrloit
Ok, thanks for your explanation: I do see them now. Strange thing. Never saw that on my system using any version of anrb. Any possibility this is some graphics driver or graphics settings issue?
dl1812
Terre,
Sorry, poor explanation - I was talking about setting the Altitude so that (for example) only aircraft above 4000' will show.
Terre
@dl1812
I see. You might want to use a quick filter for that, though it will not set the filter automatically at start up. Set the Advanced filter for the Altitude as needed and then save the filter via FILTER > SAVE FILTER AS. Activate the filter after start up via the Quick Filter tool bar.
dl1812
Terre,
Many thanks for that; as you may have guessed, I am a doughnut when it comes to Computers - which therefore for me makes this forum invaluable.
Dave L.
ACW367
How do I move the myflights list back to the left hand side of the map.  It is stuck to the right of the map, squashed with only 2 columns visible.  The only expander appears on the right butted up against the screen edge.
ACW - Menu - Tools...Interface...Interface on Left.
Hope that helps
Has anyone else noted that there have been some updates to the runways at some airports - for example, I'm sure the third runway at SeaTac wasn't there before.
I don't remember AirNav saying anything about this. Anyone spotted other examples?
lambertw
Did manual install of patches, all working fine,"well done AIR Nav".
Canonjohns40D
Another satisfied customer here also. This just gets better and better, well done Airnav and you Beta testers.
John
ACW367
First we would like to thank all the positive opinions we had until now.
Keep your reports/suggestions coming.
Rerun57
Hello
Many thanks to all for correcting the alerts/e-mail issue. It now works fine except for point noted below.
Is it possible to customize the data fields that appear in MyLog and reports? Being able to include callsigns/Flight IDs would be good - or am I missing something?
The alerts for Flight IDs do not seem to work at the moment. Might it be possible to include the use of a wildcard in the criteria for alerts by Flight ID?
All in all - a superb piece of kit!
Adrian
Quote from: Rerun57 on July 24, 2009, 06:57:24 AM
I'm sure you can use wildcards in the Flight ID Alerts section.
One of the problems you can have with Flight ID's is the way that the crew put the ID into the system.  I might use this just to make sure I get alerted on a single flight:
BA10
BAW10
BA010
BAW010
davec
hi i am having a problem installingv3.01 i get the message;
this application has failed tp start beacuse rb.11was not found reinstalling the application may fix the problem.
anybody help please
davec
