RELEASED - AirNav RadarBox 2009 - 3.01 Beta
Started by AirNav Development, July 23, 2009, 12:18:24 PM
bee46
this baby works fine again:), good job airnav
dor4x
I am using an external antenna with a 6 meters RG214 cable. My rage to the "open sky" is very nice. I am getting data from 200nm in average and picks up to 300nm.
On the mid range I gets very nice trail lines without any breaks.
This all has been changed since upgraded to 3.01.
With the network connected I can see the MSG/SEC is dropping to 0 every 10 sec+- and my nice trail lines are not as they used to be.
Also un checking the "GetFlights from the Network" doesn't work so good at my side. I am not getting any aircrafts in the list after disconnecting from the network, but I can still see them on the map..
I need to do a full RadarBox software restart in order to get fully disconnected from the network and then get my nice trail lines back.
Any other user experiencing the same problem?
pcochrane12
im getting the message drop out and also the flights dont clear when you un-check network dont need to re-start as they eventually time out but have tried it and it does clear them
cheers paul
pcochrane12
forgot to say message count drops down when im connected to the network
Marpleman
I was experiencing the opposite yesterday all day - when de-selecting the network option, the top two entries in the network tab on the screen wouldn't clear even though the flight count marker was showing zero.The flights had correctly disappeared from the map though!
The only way of clearing was to restart each time - seems ok today
On a general note my Vista SP upgrade seems fine
Also my earlier reference to connecting to Aerodata analyser to version 3.01 beta has now been sorted by reperforming the standard junction link as supplied
by Aerodata
Rich
airdata
I seem to now have a problem with aircraft not plotting on the map even though the 'globe' is present next to the status on the aircraft list.  Never was a problem on the previous (non-beta) version.
A restart of Radarbox temporarily solves the problem only for it to happen again after an hour or so.
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
Quote from: airdata on August 03, 2009, 08:26:18 AM
That was a problem with V3.0 Beta - are you sure that you are running V3.01 Beta?
The fix for the non plotting was to left click on the map and drag it by a very small amount.  I haven't seen this problem with V3.01 Beta.
davec
hi all,
i have managed to install the 3,1 beta and transfered all my inputted data, however i have notice that the network flight tally is jumping from 300-680-100, also the flights drop on the screen its very intermitant, sorry if this has been reported before, am using windows xp and new pc, anybody have anyideas that it would fix?
thanks in advance dave-c
Hi Dave,
Yes, this has been reported as is a combination of a change in the Server logic and V3.01 Beta.  AirNav are aware and are looking to fix this for the next Beta software release V3.02.  No time estimate, but it is work in progress.
davec
HI ALLOCATOR,
thaks for that swift reply, i wonder if you could help me with my next challenge, i downloaded logos from a different site as i prefer the tail logos , it worked but anav is clipping half the tail, is there anything i can do, as always i am pretty rubbish at pc etc, thanks again , well done to airnav et all for a great product and support
davec
Dave,
I've got to go out now - taking the out-laws home :-)
I'll leave you in the good hands of the other forum members and I'll get back to you later if your question hasn't been answered.
#192
davec, where did you download them from?  Sound like you might have downloaded logos designed for SBS-1 Basestation, not the Radarbox.  In which case you'll need to re-size them to 16 pixels high.
EZY example attached.
davec
Hi Tarbat, i downloaded from jacks logos as i like the tails, how do i resize them, as i say i am pretty rubish at pc s, thanks
davec
#194
I just ran the whole set through FastStone - http://www.faststone.org/FSResizerDetail.htm
Takes a couple of minutes to do all 3500+ logos, using the attached options.
