RELEASED - AirNav RadarBox 2009 - 3.01 Beta
Started by AirNav Development, July 23, 2009, 12:18:24 PM
sterigia
seems like many are going back to v2...
frank
ciao.
frank
The vast majority are still on Version 3 the latest beta.
One of the issues here is that people are not reading any of the posts and making there own minds up on certain issues.
Network:
- Last beta has aggresive timeouts so if your machine doesn't download the data intime you get timeouts of network aircraft and hence the network value changes. This will be fixed in the next version. Most of the time on a good connection this issue will not be noted.
Email Alerts:
These are being sent, please check no spam filters have been setup on your side.
Quote from: AirNav Support on August 05, 2009, 08:20:31 AMNetwork:
Will v3.02 beta use the network timeouts as setup in Preferences?
sterigia
ciao.
frank
Spaice
Airnav,  I have not set up any spam settings, I emailed a report a few days ago and it worked fine. I emailed a log at around 9:00 and again at 9:30 uk time, but never received them.  I will try again this evening, and see what happens.
regards
sterigia
well,
Network:
Email Alerts:
it is a fact that registry settings are not completely removed and nor are folders removed.
frank
ciao.
frank
slipdog
Airnav,
i have no spam setup either, but this is the only time it has ever happened to me, this could be down to ISP or mail provider etc, maybe not ANRB, i only mentioned it because it happened to someone else. Keep up the good work, i'll try the next beta when its released before i move off v2 again.
Rich.
davec
hi airnav,
i am working beta 3.0,and it works fine apart from intermitent route omisions, however if i use 3.1 network is unworkable, as it does what other people have reported,i only mention this  because it may help to sort out the next fix
regards davec
sterigia
support,
i am only moaning to let you know the issues that are to be fixed. like davec
saluti
frank
ciao.
frank
Spaice
Airnav,  I have tried once again to email my log report without success, no spam filtering has been set up, is this something you are looking into as it was fixed with patch 1
Spaice,
Not at the moment, its working for everyone else and our closed beta testers said that issue was fixed as well.
When you mean email mylog report? Do you mean your trying to send the report for the day.
Spaice
Hello Airnav,
Ok I have to eat humble pie, for some reason googlemail decided that the reports sent via Airnav were spoofed using my name and put them into spam.  It has taken me some time to work out what was happening.   Sorry about that, but it was not obvious nor did googlemail show the email as spam it just hid them all.  Sorted now though.
Paulc
Have just down loaded the 3.01 beta and can still report that alerts are not working for me. Having seen a couple of the aircraft appear on the dataline but receiving no alert message being received i am unsure as to what to do next. Any suggestions ?
Alerts worked fine on v2.
FlightChaser
So Airnav was right all along Spaice. It's good you apologised and you got your problem sorted in the end. It takes a real man to admit he got it wrong, well done!
