RELEASED - AirNav RadarBox 2009 - 3.01 Beta
Started by AirNav Development, July 23, 2009, 12:18:24 PM
#240
Quote from: EINN-07 on August 08, 2009, 12:09:23 AM
I've read through the previous 16 pages of posts on this topic so apologies if I've missed this...
Has anyone else noticed this problem with 3.01 ?
I'm happier than a pig in manure with the latest version -  ATRs, Embraers and bizjets are all throwing up flight numbers and routes (because that box is ticked), something that wasn't available on my previous versions.
However... and this is the bugbear from previous versions... I input the full details for N407BV an A320 due Shannon tonight prior to it's pickup on the box. I have 'Auto Populate Aircraft Data' and 'Download Aircraft Photo' ticked in the preferences box but when the aircraft was picked up, Database Explorer was populated (overwritten ! :-(  ) by 'Tie up extracted from Country Sequence' in the A/C Name field.
This has happened on so many occasions now that I have a real pain in my breasts  with the problem. I also find that for 90% or so of new aircraft picked up that the 'AT' field is populated as three dots in Database Explorer, all other fields correct. Apart from that I'm really happy with V 3.01 and I don't really want to untick the 'Autopopulate' box as it was a real pain updating the dB manually prior to his.
Speaking of 'untick' can we not have an 'opt in' rather than 'opt out' option for 'Share Data' in Preferences/Radar Box. If Ryanair can do it, surely to God Airnav can do it also ?
When it eventually works !
JStobbie
Since moving to Beta version 3.01 I have had a some strange activity in the Reporter log .... basically if either G-BWDB (ATR72) or JA736J (B777) should be logged they appear thousands of times!! and I do mean thousands. I had both one day this week and the total logged for the day was some 27,000 !! ... there used to be a few instances of these 2 aircraft previously maybe a dozen or so times over a few minutes but this is just crazy.
viking9
AirNav,
This seems to be tied up with the problem I have. I output data from port 30003 to PlanePlotter servers and since installing V3.01 beta my RB has been sending spurious aircraft data to the PlanePlotter servers, causing them to ban me from sharing.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Quote from: viking9 on August 08, 2009, 11:48:25 AMI output data from port 30003 to PlanePlotter servers and since installing V3.01 beta my RB has been sending spurious aircraft data to the PlanePlotter servers, causing them to ban me from sharing.
Strange.  I share onto the Planeplotter network (sharer pQ), and I haven't been banned.  What IO option are you using in PP - the following work okay:
1. SBS1 tcp (port 30003)
2. Radarbox tcp (port 7879)
I use port 7879 now.
Quote from: viking9 on August 08, 2009, 11:48:25 AMThis seems to be tied up with the problem I have. I output data from port 30003 to PlanePlotter servers and since installing V3.01 beta my RB has been sending spurious aircraft data to the PlanePlotter servers, causing them to ban me from sharing.
I'm not up to speed with the latest versions of PlanePlotter, but it occurs to me that if up to now the RadarBox 30003 output wasn't compatible with the SBS's, then presumably PP takes that into account when you tell it that the output is coming from a RadarBox ?
Now that it is compatible, have you tried telling PlanePlotter to expect SBS-format output ?
Quote from: DaveReid on August 08, 2009, 12:51:44 PMNow that it is compatible, have you tried telling PlanePlotter to expect SBS-format output ?
Exactly.  Either use SBS tcp (30003), or Radarbox tcp (7879).  Do not use Radarbox 30003.  This was discussed on the Planeplotter forum when I was closed-beta testing v3.
viking9
Tarbat and Dave,
I must have missed those posts - I do tend to spend my time actually tracking aircraft with mlat rather than reading all the posts every day.
Strange that Bev didn't mention it when I had the prob. I'll reinstall v3.01 Beta and try RB tcp.
Thanks for the info guys.
Tom
Tom
15 miles SE of EGUN
Fenris
One thing I've noticed is that if I go to full screen on the map and then back to the normal window, the map scale changes considerably.
I would expect it to come back to where it was originally.
I don't know if this is the same as it was on v2.01 as I could never get the map to show after coming back from full screen.
Paulc
Alerts still not working on V3.0 or 3.1 - worked ok on v2.0
Paulc,
Can you explain what your entering? for most people this is working fine.
Paulc
Am only entering registration info (ie G-FLC* for new Flybe DHC8)  for specific aircraft and as on V2 would hope to get an on screen message pop up. Had one appear on dataline yesterday evening but no alert.
viking9
I'm missing some airport names and codes  e.g. Heathrow, Luton, Whilst Gatwick, London City and others are showing. Any ideas? I did a search but couldn't find this mentioned before.
Tom
Tom
15 miles SE of EGUN
 I quite often get instances where Glasgow and Prestwick airport names do not appear when the 'Fix' for Lanak is named on the map. If I turn Fixes off and then on again, up pops the names for Glasgow and Prestwick Airports but no name for the Lanak fix although the actual triangle symbol is shown. Most strange. I'm sure it did not happen with the previous version 2.
viking9
Ian,
Thanks for that tip. I turned on FIX and the missing names reappeared. Turned FIX off and they remained.
Tom
Tom
15 miles SE of EGUN
Tom,
Probably difficult to tell unless you also study a particular 'Fix' as I do with Lanak as it is the main one for Glasgow and Edinburgh airports but did you notice if any of the names of the 'Fixes' disappeared when you got your airport names back ?
