Network
Started by EK01, July 23, 2009, 08:35:33 PM
lambertw
I didn,t notice this problem yesterday.
Hosch
Airnav, I think we need a patch soon for the network to work correct again.
Greetings from Luxembourg
lambertw
Network totally unusable at moment.
jasper37
same problems here too in the UK
Terry
Hi there,
             Network down and i`m using version 3.0 beta,very strange?It has been fine until version 3.1 beta release?
If the network is important to you, then just revert to v3.0 beta.
Guys Please read our comment about Version rather than posting about what you tihnk is happening with the network:
We have worked out whats happening:
The network timeouts in Version 3 are now strict. So if you fail to get a download update from the server or takes it longer than imagined you will end up in the network traffic timing out and hence changes in the numbers.
In future version we will increase the timeout so a longer download or failed download doesn't result in removing of network aircraft untill after a longer period of time.
carp777
i have not updated to v3.01 i am still running version but i am not getting any network flights at all
                            Bryn
Terry
Hi Tarbat,
             I am using 3.0 Beta version,still no network flights,after i downloaded 3.1 Beta version,"bong" network flights went on and off,so i returned to Beta 3.0,but i`ve just got a yellow network connected box and 0 network flights.How strange,disregard this post as the network has just returned.
     Best Regards Terry.
The network had some quick maintenance to see if we can improve the speed. It should be running now.
Terry
Thanks AirNav,
                      Network up and running,100% on the ball as usual.
        Regards Terry.
carp777
network off again
       Bryn
Terry
Yep,
      Same here Bryn,think i`ll turn it off and try again later in the day.
   Regards Terry.
itestoo
Network down here in france too, with 3.0 and 3.01 version
Good luck to find what happen's
Regard's
Laurent
www.radarvirtuel.com
sterigia
network on and off for me using beta 3.01 and a vista machine, location sardinia
frank
ciao.
frank
