Network
Started by EK01, July 23, 2009, 08:35:33 PM
Anyone else experiencing problems with the network tonight. Info seems to be very erratic. At the moment nothing is coming through.
CAM
Same here, very erratic
We are investigating this issue. Can you confirm also which version you are using?
John Racars
Hi Support and All,
Same here as well after installing V 3.01 Beta....
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
radarspotter10
Quote from: John Racars on July 23, 2009, 09:01:48 PM
Hi Support and All,
HI
same here happen after installing v 3.01 beta
from pat n.ireland
Canonjohns40D
Hi I also have noted this, again after the installation ofv3.01 beta.
John
John Racars
Hi Support and All,
At this moment the Network is stable again with me. I have running it for more then a half-our without any problem.
13 NM East of EHAM
ANRB:
54901 - Jim
My network flight total showed (0) for a short while, just a few minutes ago.
Jim
Oshkosh
(Using 3.01 on Vista)
KOSH - Oshkosh, Wisconsin USA
At the moment seems to be ok. Using Vista.
We have worked out whats happening:
The network timeouts in Version 3 are now strict. So if you fail to get a download update from the server or takes it longer than imagined you will end up in the network traffic timing out and hence changes in the numbers.
In future version we will increase the timeout so a longer download or failed download doesn't result in removing of network aircraft untill after a longer period of time.
Thanks Airnav,
Canonjohns40D
Hi Airnav and thanks for the info. Just now 4 network flights only showing on my box.
John
pcochrane12
networks in and out like a fiddlers elbow this morning currently 1 flight showing
cheers paul
lambertw
Ya, same here must be network problem.
Its a timeout problem in the v3.01 beta, which Airnav have said will be fixed in the next beta release.
You might want to revert to the previous version if the network is important to you.
Quote from: AirNav Development on July 24, 2009, 01:57:50 AM
The reason for this is easy to explain: network flight position expires if not updated within 30 seconds. Data is downloaded form the network in 30 seconds too. So if there is a delay on an internet data download, lat/longs will be cleared and as the network grid (as per a request received here) only shows flights with lat/long...
In resume we will change the timeout to 60 secs instead of 30.
