Author Topic: * 39009C ZZZZZZZZ what is this plane ?  (Read 7960 times)
itestoo
    • Radarvirtuel
« on: August 01, 2009, 08:08:20 AM »
Generated at 2009/08/01 00:00:01 UTC
Valid for 2009/08/01
3037 Flights Logged
   Mode S  Flight   Route           Regist  Airc  Airline              Date and Time
 * 018032        2009/07/31 17:26:45
 * 060020  MAU42                                                       2009/07/31 07:11:40
 * 060020  MAU53                                                       2009/07/31 19:32:30
 * 12004A        2009/07/31 11:32:23
 * 39009C  ZZZZZZZZ                                              2009/07/31 15:39:33
 * 39177C                                                             2009/07/31 11:19:13
 * 392232  AXY771                                                  2009/07/31 06:29:54
 * 394C14  AFR234P                                                2009/07/31 08:09:48
 * 395701                                                               2009/07/31 18:44:52
 * 39801C                                                               2009/07/31 11:44:43
 * 398508  AAF301   LFPO-LPPT                                 2009/07/31 08:05:06
 * 398D1C  FJHDZ                                                    2009/07/31 11:32:18
 * 3B7777  FAF406                                                   2009/07/31 09:24:21
 * 3B777B  MERL400                                                 2009/07/31 11:06:24
I cannot find the registration for this callasign, is ther anyone how capture this aircraft ?
Regard's
Laurent
www.radarvirtuel.com
Re: * 39009C ZZZZZZZZ what is this plane ?
« Reply #1 on: August 01, 2009, 11:22:41 AM »
Laurent,
According to airframes.org the mode S code is for a French registered aircraft but no details have been found. Same with the GAS site therefore, so far, a mystery.
DVDW
  • RadarBox Beta Testers
« Reply #2 on: August 01, 2009, 02:34:27 PM »
At this moment, i'm receiving a similar flight ID with a different mode-s code:
447A7A  ZZZZZZZZ       2009/08/01 14:14:14
Greetz,
Dirk
Belgium
« Reply #3 on: August 01, 2009, 06:44:03 PM »
Dirk,
According to airframes that code relates to Austria. Again no further data. Very strange.
« Reply #4 on: August 02, 2009, 06:50:23 AM »
The French code is most likely a microlight in the F-Jxxx range, and I'd guess that the Austrian is too - maybe we're looking at the default callsign programmed into a handheld Mode S transponder?
« Reply #5 on: August 02, 2009, 11:37:27 AM »
Thanks for that Dave.
If you should see the same thing coming up on your RB, perhaps you could do a bit of investigating. I'm not really website savvy therefore apart from GAS and airframes websites, wouldn't really know where else to look.
Cheers,
    • Rod's RadarBox Downloads
« Reply #6 on: August 02, 2009, 11:49:54 AM »
Just to add my twopence-worth, I regularly get RAF BN2T ZH536 (Mode-S 43C38B) buzzing around usnig ZZZZZZZZ.
« Reply #7 on: August 02, 2009, 12:50:17 PM »
Rod,
Now there's a coincidence. I picked up the same aircraft today at 12.42 transmitting as you say Mode S 43C38B a BN2T registration ZH536 with an ID of ZZZZZZZZ. I think that was the correct number of Z's. Maybe the pilot is asleep and it's on automatic pilot !
Cheers,
« Reply #8 on: August 02, 2009, 01:24:38 PM »
Ian - if it's coming up with the snooping logo that I did some time ago, you've got the right Z count!
