Slowwwwww....
Started by Deadcalm, August 12, 2009, 01:35:59 PM
Deadcalm
Look, I don't know whether it's just me, but this forum is getting slower...  and slower...  and slower.  If others are also experiencing this, can Airnav tell us a). What's happening, b). Are they going to fix it and c). How long until they do?  It all seems to be dragging on a bit.
If it's just me, can anyone suggest why, and how to improve things other than by clearing my cache, which I do every day?
DC
The server has been busy recenetly which has caused it to a slow a bit but nothing to suggest its slowling enough to be noticable.
Is there a specfic point where its slow?
abrad41
I have also notice the site has been slow lately.
I can work with it, but it is slower than it was before.
Andy
We are investigating this problem and will let you know when we have a resolution. It is identified but not solved at this time.
John Racars
Hi All / Support,
With me this forum works normal. I am logging in more times a day. That this forum should be slower and slower is not perceptible with me.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
prbflight
The forum is working fine on this side of the pond.
Paul@cyyb
artnco
I have been accessing the Forum for almost 2 years now, but the last couple of weeks or so have been painful in terms of access time. I access several times a day at different times and the problem is there all the time.
Many thanks to Support and hope the problem identified is soon rectified
I'm accessing the forum via 3G Mobile Broadband and it seems to be running at normal speed for me - no slowness seen.
I find it may be slightly slower to open initially, but checking through threads and to post, very quick.
Jeremy
No different with me and I am on hols with dial-up!
J.
G4DOQ
QRZ.com
No problems here - accessing thru V.2
viw
Hi airnav,
no problem with my connection - via dsl
cheers, gerald
Marpleman
Been "as normal" for me all this week - no problems at all, both via my normal log on at home and as a guest from my workplace (tut tut!)
Rich
radarspotter10
Quote from: Marpleman on August 12, 2009, 09:07:44 PM
Rich
hi.
no problems here bt internet.
from pat  n. ireland
The problems we are experiencing are rare and happen only from time to time.
