RELEASED - AirNav RadarBox 2009 - 3.01 Beta - Part 2
Started by AirNav Development, August 13, 2009, 10:06:18 PM
0 Members and 10 Guests are viewing this topic.
simone.simone
#30
After some experiments with both ANRB2.0 and ANRB3.01 Beta, and two different PC (but same internet connection), I've found this:
- if I'm offline all works fine, same if I don't request "Network flights" or any METAR/TAF into "SmartView".
- otherwise during "Network flight data request" and "Weather request" by "SmartView" (no problem for request using "Get Weather") all traffic is freezed till the server request is finished. Sometimes this last only 1/2 seconds but this time can increase if I put more than one ICAO into "SmartView" and reach 15/20 seconds if the internet connection is busy for some reason.
Spaice
I have the same issue, and no longer use the network function because all aircraft traffic freeze including live traffic, if I turn network data off then aircraft moves on the screen every second this also leaves a nice un-broken trail behind the aircraft.
simone.simone
Quote from: Spaice on August 19, 2009, 08:54:20 AM
Me too, the worst problem is that also the record will suffer of traffic data loss, but at the same time I would like to keep the METAR/TAF request into SmartView, beacuse it's very useful to the have the "Auto Set QNH" option turned on.
Spaice
marcdeklerk
any change we can have that when I Autopopulate the database, the MYLOG data is also updated at the same time?
thanks guys, keep up the good work!
leading light
Air Nav-I am not sure if you are still looking for reports of particular problems with alerts but in case you are here is my experience
Beta 3.01 - I have found that alerts on network are no problem as may be expected but on my own hardware although I receive "in Range" alerts I do not appear to receive them on Callsigns, Aircraft type or Squawk.  Whether I use wildcards or not makes no difference.
Quote from: marcdeklerk on August 20, 2009, 10:04:16 AM
MyLog is populated when you use MyLog > Tools > Populate - however, only blank fields will be populated, so if you have '...' in the aircraft type, this must be deleted before Populate will work.
GlynH
Quote from: Allocator on August 20, 2009, 08:38:17 PM
Hi Allocator,
And how best to delete all occurrences of '...' from MyLog.db3?
The thought of going through it manually, right-clicking, delete, right-clicking, delete thousands of times fills me with horror! ;^)
Are there any occurrences of '...' in NavData.db3 that might need to be removed also?
Thanks & regards,
-=Glyn=-
GlynH
Quote from: tarbat on August 21, 2009, 07:44:52 AM
Quote from: AirNav Development on August 19, 2009, 12:09:43 AMWe plan to release V3.02 on our beta forum this Friday.
Today's the day - hooray!!
Based upon previous experience if AirNav release this on time then I'll eat my...errr...breakfast! ;^)
Kind regards,
-=Glyn=-
marcdeklerk
simone.simone
Is it possible to correct the option that makes "Share Flight Data" always checked when restarting the program?
Deadcalm
That is a sore point, apparently.  Many of us have asked for that checkbox not to be "on" at programme start up.  It's obviously defaulted in the checked position for a reason - I think we all came to the conclusion that it was in Airnav's interests to have users share their traffic by default because without sharing, this (and other Airnav products) would suffer a dearth of data.
Personally, I think the option should be unchecked by default, but I suppose there will always be arguments for and against, and it won't be changed.
DC
