Author Topic: sp-3 splitter and bias T  (Read 3729 times)
radarphil
« on: August 14, 2009, 10:58:00 AM »
i have just got a sp-3 splitter to connect two radarbox to same aerial how do i incorporate the elad bias T any help would be appreciated
regards phil
Fenris
Re: sp-3 splitter and bias T
« Reply #1 on: August 14, 2009, 06:39:14 PM »
So you have a preamp as well? If so then you need the bias tee on the antenna/pre-amp side of the splitter. Otherwise (no pre-amp) you don't need it, but I assume you already have it because you do have a pre-amp.
radarphil
« Reply #2 on: August 16, 2009, 08:57:52 PM »
sorted out thanks
