Author Topic: Aircraft not displaying on the map - any ideas?  (Read 4044 times)
markyeulett
« on: August 15, 2009, 04:02:37 PM »
I have the software running on 2 laptop PC's (both XP) and get the same aircraft in the grid window.  However, I get all the flights displaying (that should) in the map window on one PC but on the other I get much less and then over time I get none.  I have uninstalled and re-installed the software but this does not help.
I am running the 2009 v 2.0 software and not the new Beta (as thye laptop with the problems a Dell Inspirion 6200 will not run ther beta software).
Any ideas?
mark
Re: Aircraft not displaying on the map - any ideas?
« Reply #1 on: August 15, 2009, 04:10:08 PM »
Not sure what you mean that they won't run the beta software?
markyeulett
« Reply #2 on: August 15, 2009, 04:38:09 PM »
one does but one does not as I get a Microsoft failure message saying that anrb.exe has encountered an error in loading.
but that is not may main problem - the problem is aircraft not appearing on the map (or they do for 10 mins or so then they stop displaying yet i can see them in the list).  If i unplug USB and plug into other machine they display immediately.
« Reply #3 on: August 15, 2009, 05:15:33 PM »
That issue about the beta was in the first beta. A second beta has been released.
We haven't had any similar issues with version 2 that you mention.
markyeulett
« Reply #4 on: August 15, 2009, 05:35:08 PM »
what is link for 2nd beta download ? - i will try that one and let you know
I have rebooted macxhine completely and the map display seems to have rectified - will come back if re-occurs?
« Reply #5 on: August 15, 2009, 07:11:23 PM »
Beta V3.01 is the last release, available here:
http://www.airnavsystems.com/forum/index.php?topic=3141.0
