Author Topic: Airport approaches  (Read 11617 times)
    • Rod's RadarBox Downloads
Airport approaches
« on: August 24, 2009, 07:33:42 PM »
Can anybody please explain to me why it is that, while most aircraft approach an airport directly to land, on other occasions an aircraft directly overflies the airport, and then does a half or a full circuit.
On my recent flight to Preveza, Greece, our BMI A320 approached the landing runway, flew about 3000ft above it, did a full circuit, and then landed. Would this have been a missed approach or go-around, or is there a procedural reason for it? I'm pretty sure that it was all totally controlled, for example no sudden use of go-around power, and I don't think the landing gear was lowered until we were established in the circuit.
I see this happening on my RB at Blackpool quite often too. Is it a coincidence that these are both relatively quiet airports?
DougV
Re: Airport approaches
« Reply #1 on: August 24, 2009, 07:59:00 PM »
Hi Rod.
Have a look at this page and scroll down to Circling Procedures.
G4SEQ
Located 10NM South of EGNM
EMA
« Reply #2 on: August 24, 2009, 08:16:22 PM »
This is sometimes done to reduce the aircraft height at a slower rate, basically an extended approach.
« Reply #3 on: August 24, 2009, 09:52:58 PM »
OK - I get the idea - many thanks, chaps.
