acars
Started by oldun666, August 27, 2009, 10:13:53 PM
oldun666
hi folk's being new to the rb, could anybody tell me what i have to do to recieve acars, i have the lead from comp to scanner and someone told me to d/load www.zorg.org which i have and downloaded the preface but when i click on monitor  acars or pager, nothing happens do i need anything else ie software could somebody please tell me  what to do in simple terms that a 62 yr old brain can understand,  thank's all    jeff.
John Racars
#1
Quote from: oldun666 on August 27, 2009, 10:13:53 PM
Hi Jeff,
1. you should install ACARS-decoding software on your PC;
2. you should connect a scanner on an (outside) antenna and your PC;
3. make sure that software and scanner work together;
4. you should tune your scanner on one of (or all) frequencies mentioned in my signature below (when you are situated in Europe)
If you did as I described above you should recieve ACARS.
Hope this helps.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
nortonbeak
There have been a number of free programs available to decode ACARS available on t'net. The sites seem to have slowly disappeared.
The only one I can readily find is for ACARSD and is
http://www.acarsd.org/download.html
Of course, AirNav have their own ACARS decoding program and details are at
http://www.airnavsystems.com/ACARS/index.html
Jeremy
Is that ACARS data translated into an aircraft position on the RB screen or does it remain as strings of data?
J.
G4DOQ
QRZ.com
John Racars
#4
Quote from: Jeremy on August 28, 2009, 09:08:39 AM
Hi Jeremy,
No that is not. ACARS is a way of communication between an aircraft and ground. It will be used for sending all kind of reports and messages like weatherinformation, clearances, failures/defects, flightplans, engineeringdata etc.
Below an ACARS-massage showing the next waypoint in the flightplan of this a/c that is actually enroute from Manchester to Doha in Dutch airspace:
ACARS mode: E  Aircraft reg: .A7-ACH [A332]
Message label: 16  Block id: 7  Msg. no: M57A
Flight id: QR0042 [EGCC-OTBD]
Message content:-
ARNEM  ,N 52.366,E  4.488,35793,271
-------------------------------------[28-08-2009 11:43]
13 NM East of EHAM
ANRB:
pjm
Quote from: John Racars on August 28, 2009, 09:46:46 AM
Below an ACARS-massage showing the next waypoint in the flightplan of this a/c:
What does this one mean?
ACARS mode: S  Aircraft reg: VH-EBE  [ ]
Message label: 87 [Aircrew addressed downlink]  Block id: 7  Msg no: M37A
Flight id: JQ0037  [SYD-DPS]  [JetStar Airways]
Message content:-
JST37 OUT 0741 OFF 0759
ETA 1405. DElAY DUE NOTUG DRIVER
----------------------------------------------------------[ 28/08/2009 18:08 ]
John Racars
Aircraft has delay due to "NOTUG DRIVER". Sorry, I do not know yet what that means...
13 NM East of EHAM
ANRB:
I presume it means that they can't get a pushback from the stand because the tug driver hasn't turned up. Bet they wish they were a turboprop with reverse pitch!
John Racars
Quote from: RodBearden on August 28, 2009, 11:38:30 AM
Hi Rod, thank you!
Sounds verry plausible to me.
13 NM East of EHAM
ANRB:
oldun666
thanks for the info folks ive tried to d/load acars etc but to no avail my comp dosn't want to play, must be vista playing up.
nortonbeak
Quote from: oldun666 on August 28, 2009, 10:02:13 PM
Which version of ACARS have you tried?
oldun666
hi there the one somebody told me about and which ive tried is www.nathan.chantrell.net  thanks jeff
DougV
Hi Jeff.
I used the old WACARS programme a long time ago and it worked fairly well.
You can still get it from here but I don't think it is supported any more.
It may be OK for you as a start.
Doug
G4SEQ
Located 10NM South of EGNM
John Racars
Quote from: DougV on August 29, 2009, 12:03:48 PM
It was never...........
But with me it was always working OK as I can remember. I am not sure this software works together with the PC soundcard; if that is not so indeed, the use of an ACARS-decoder (p.e. Lowe Electronics) is necessary!
13 NM East of EHAM
ANRB:
DougV
Yes it does work with sound card input.
Not the best prog in the world but functional.
I have also used ACARSD and AirNav's too.
Just getting back into things after some time concentrating on other things.
G4SEQ
