rb.dll
Started by vassylad, September 02, 2009, 12:22:17 PM
vassylad
Hello guys, I have been busy lately and I noticed that V3.01 is in use, when I try to upgrade I get the following message at the end of the download can anyone help please.
X This application has failed to start because rb.dll was not found.
Re-installing the application may fix this problem.
I have tried to re-install it but his keeps on popping up.
Thanks Michael
Hi Michael
It sounds as if you're not installing the upgrade in the correct folder, which should be something like C:\Program Files\AirNav Systems\AirNav RadarBox 2009
If you keep having problems, try doing a full install rather than the upgrade.
HTH
vassylad
Hi Rod, good morning mate, thanks for your help it worked a treat.
Michael
colinhall
Rod, I have put the full download onto my new pc at home and it puts the map on the screen but not any traffic?. sorry to be a bit stupid but do I still have to put the disk on first that I got to start with? Colin.
colinhall
Anyone know what the heck is all that on the aviation part????? of the forum!          Colin.
It was a spammer, its been cleared now.
Colin,
Have you installed the drivers on your machine as per:
http://www.airnavsystems.com/radarbox/help/installation.htm
colinhall
Hi Airnav, sorry late getting back to you.Just home from work. Have put the disc in and done what it says on the screen,but I get all on the screen except traffic. It says hardware not connected!and is showing a red square. On the box itself the signal and the usb light(blue)are both flashing together ,about 2 flashes to 1 second.When I run the cd it didnt show all the windows as per the installation above. Colin
73TORANA!
Hi Colin ,try another USB cable I had probs with mine .
colinhall
The box works perfect on my laptop so I must be doing somrthing wrong. Will try what Tarbat says above,thanks for that anyway. Will have a go when I get home from work this pm Tarbat. thanks. Colin.
colinhall
Tarbat, HELP! can you please me E mail me a number I can call you on please. I have been through the above root you gave me and there is not a driver on the p??? Colin.
Can you explain where you get the issue? at what stage, what error message do you get?
colinhall
Hi Airnav I get this message when I try to go through the system that Tarbat said try,9post 1951). There does not appear to be a driver on my pc?. I have put the cd in that you supplied when I first got the AVRB but nothing???.Colin.
We have contacted you directly for some steps to try.
colinhall
Thanks for that Airnav.Will have had my son down for w/end with my grandson so will try it asap. Colin.
