Author Topic: Duplicate alerts - popup & email  (Read 25479 times)
pjm
  • RadarBox Beta Testers
« on: September 06, 2009, 07:47:28 AM »
Another weird problem with the beta
I'm getting every alert twice - even in the log screen they appear twice (see below)
I have set a couple of different alert types, and whenever one of the conditions is triggered I get 2x pop-ups and 2x emails for the alert.
EMA
Re: Duplicate alerts - popup & email
« Reply #1 on: September 06, 2009, 07:55:50 AM »
Not seeing that here.
« Reply #2 on: September 06, 2009, 08:10:16 AM »
PJM, maybe that is because you are getting an alert on VH-OJK and on all A380 aircraft.
Effectively, you have got the 'same' aircraft set to alert by Registration AND Type and I think that this is confusing RB?
You are right, it shouldn't happen like this though.
P.S. be careful with screen shots that show personal stuff like email addresses.
« Last Edit: September 06, 2009, 08:13:33 AM by Allocator »
pjm
« Reply #3 on: September 06, 2009, 09:57:28 AM »
Not sure if I understand your reply.  VH-OJK is an B744 not an A380 if that was what you meant. Otherwise I'm not sure what you're trying to get at.
fwiw I wouldn't have posted a screenshot with my email address in the public forum, but then again I have some pretty good spam filtering, so not much harm to be done :)
« Reply #4 on: September 06, 2009, 01:01:16 PM »
Sorry - brain fade :-)
Don't know what made me think that VH-OJK was an A380 - too early on a Sunday morning!
pjm
« Reply #5 on: September 12, 2009, 04:43:31 AM »
I'm still receiving duplicate alerts with the latest beta.
I've gone so far to remove RB totally & reinstall. I've only restored the 2x *.db3 files & D012.dat & D008.dat, but that hasn't resolved anything.
Now I've added some wildcard flightid's to the alert panel and this is where it gets interesting :)
I don't get duplicate alerts for the "Flight ID"'s only "Aircraft" (and maybe Registrations - but I haven't seen that plane recently so not sure about that one.
« Reply #6 on: September 12, 2009, 06:34:51 AM »
If you scroll down your Aircraft alert box, can you confirm that you only have B744, A80 etc entered once?
« Reply #7 on: September 12, 2009, 06:41:50 AM »
Even better, exit Radarbox and then check the contents of HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\General\memo4text in the Registry.
There must be something different about your alerts setup that's causing this.  I have several Aircraft Type alerts setup, and don't see duplicates.
« Last Edit: September 12, 2009, 06:47:53 AM by tarbat »
pjm
« Reply #8 on: September 12, 2009, 07:15:05 AM »
Confirmed - everything is only there once. Even more bizarre now I have just received only 1 alert for an A380 now! Now it seems to be randomly duplicate!
pjm
« Reply #9 on: September 12, 2009, 07:18:17 AM »
pretty much same as before (just the new options)....
« Reply #10 on: September 12, 2009, 07:22:19 AM »
pjm, I just wonder why the registry on your PC shows those little square symbols in the key text, whereas mine doesn't?  Probably nothing to do with the problem, but it's strange.
« Reply #11 on: September 12, 2009, 07:30:26 AM »
I've got the little squares too, so probably unrelated?
On the other hand, the squares seem to be a divider, so maybe squares AFTER the entry are a bad thing?  PJM, try deleting 'blank spaces' after your entries in the alert boxes.
« Last Edit: September 12, 2009, 07:34:41 AM by Allocator »
pjm
« Reply #12 on: September 12, 2009, 07:32:47 AM »
Maybe something to do with Windows default font or codeset? I also have ALL the Windows special/fancy effects turned OFF to speed up graphic performance.
fyi the little squares are non displayable characters (cr/lf in this instance)
« Reply #13 on: September 12, 2009, 07:36:49 AM »
Good idea.  Didn't this cause a problem with alerts ages ago?
« Reply #14 on: September 12, 2009, 07:37:54 AM »
I'm sure that it did.
