RadarBox Network Uptime Stats - Aug 2009
Started by AirNav Development, September 08, 2009, 01:17:31 AM
Period Begin: 2009-08-09 01:14:52 GMT
Period End: 2009-09-08 01:14:51 GMT
Date Outages Downtime Uptime%
2009-Aug-09 Sun 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-10 Mon ^ 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-11 Tue 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-12 Wed 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-13 Thu 1 0 hrs, 17 mins, 36 secs 98.778%
2009-Aug-14 Fri 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-15 Sat 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-16 Sun 1 0 hrs, 20 mins, 5 secs 98.605%
2009-Aug-17 Mon ^ 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-18 Tue 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-19 Wed 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-20 Thu 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-21 Fri 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-22 Sat 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-23 Sun 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-24 Mon ^ 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-25 Tue 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-26 Wed 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-27 Thu 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-28 Fri 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-29 Sat 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-30 Sun 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Aug-31 Mon ^ 1 0 hrs, 19 mins, 51 secs 98.346%
2009-Sep-01 Tue 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-02 Wed 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-03 Thu 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-04 Fri 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-05 Sat 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-06 Sun 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-07 Mon ^ 0 0 hrs, 0 mins, 0 secs 100.000%
2009-Sep-08 Tue 0 0 hrs, 0 mins, 0 secs 100.000%
Total: 3 0 hrs, 57 mins, 32 secs N/A
Average: 0.1 0 hrs, 1 mins, 51 secs 99.863%
Jeremy
Airnav,
we have to talk the same language here. It may not be the main server that is down but I lose the network every 5 mins or so and it is not my internet connection. So please do not try and justify it with those stats. Other people see the same so it is not just me.
I am being patient for the next version so please do not hit me with that Beta testing phrase again.
There is a problem and it would be nice if Support acknowleded it!
Jeremy
G4DOQ
QRZ.com
EMA
If it was a problem would we all not see it?
sterigia
i have to use version 2 otherwise i get downtime with the servers, regardless of what support says. the beta is not working well enough to install yet.
frank
ciao.
frank
Jeremy,
If your using beta version then there is an issue with it regarding the network and we mentioned this on the beta thread quite a few times.
I think some of you are still unaware of what a beta means and also that its unsupported as its not a finished stable version.
Fenris
Quote from: sterigia on September 08, 2009, 09:11:09 AM
Unless you're not using the network in which case it's vastly superior to v2.01 in virtually every situation.
When 3.03 (or whatever version had to be reached to fix the remaining bugs) is released you will not have this problem.
Jeremy
EMA - you will only see it in the Beta version.
Frank - Thank you.
Ferris - Thats a bold statement. Are you sure about that?
Airnav - I know, I know, I know! so why cut and paste you server activity report at the top of this thread? You are making a statement that there is not a problem with your server then saying the beta version does have a problem.
Soory! Frustration setting in as Airnav did suggest the new corrected version would be out several weeks ago.
I will go back to v.2 and look forward to the new version. I will also shut up and go and play with another toy!!
Jeremy.
G4DOQ
QRZ.com
radarspotter10
Quote from: Jeremy on September 08, 2009, 11:03:11 AM
Frank - Thank you.
Jeremy.
hi Jeremy.
A bit confusion all right, airnav next time you post network times say this excludes the beta version, you would save all this crying, and airnav we are going round in circles with these posts.
http://www.airnavsystems.com/forum/index.php?topic=3362.0
from pat.
Fenris:
"When 3.03 (or whatever version had to be reached to fix the remaining bugs) is released you will not have this problem."
I'm sorry but you clearly don't know about the programming and technical details behind the software so it would be better if you avoided these kind of false comments.
V3.02 corrects all previous versions bugs and because of very strict time-out value it gives problems in some users machines with less reliable internet connections (time-out is 30 secs only an download interval is 30 secs so if you miss a download all network flights will be time-out).
Next time try to make more valid/correct comments otherwise it would be be better not to post.
Steady on, Dev - I don't think Fenris deserved those comments - unless I missed something, what he said was about right.
Jeremy
Quote from: AirNav Development on September 08, 2009, 12:22:42 PM
Fenris:
But Airnav - my internet connection is 100%.
I think, therefore, that perhaps my machine can not take the download and process the data at the same time hence then timing out?
J.
G4DOQ
QRZ.com
Jeremy
Perhaps the minimal PC spec needs amending.
J.
G4DOQ
QRZ.com
Let's not start a confusion here.
As our support wrote, until now any V3 is a beta version: this means that users should use it at their own risk. It's a test version.
Regarding Fenris comments:
"Unless you're not using the network in which case it's vastly superior to v2.01 in virtually every situation."
This is not correct at all (also explained above why). Users have to pay attention to what they write on the forum otherwise there is a risk of giving a false idea of what's going on to other users.
V3.03 is about to be released and everybody will be happy by then. We are just waiting for 2 users to confirm their reported problems were corrected.
Fenris
#13
Quote from: RodBearden on September 08, 2009, 12:29:30 PM
Well Rod, the last time I got my feathers singed by Airnav it was because I was "asking strange inside technical questions" and now it's because I do not have any knowledge of what is happening. You can't win <vbg>!
To recap my opinion:
V3.01 *beta* has a problem with network flights under certain circumstances. Personally I have used it because it works better for me that V2.01, I don't use the network much. When I have I have seen the same problem, where network flights disappear for a while on some refreshes. I'm aware that this is the nature of betas.
V3.02 *beta* has not been released for testing to other than the closed beta group, so I don't know if it fixed this network flight issue. But some (other?) things clearly weren't quite right as Airnav stated that another release is needed to fix the last bugs.
V3.03 (which might be labelled a beta, and might not) should have all of this sorted out.
Sincerely Airnav, I was not trying to be awkward, just pointing out that the original complaint was unreasonable since you have said repeatedly that a beta can have bugs.
Everyone happy now?
EMA
