V3.04 Available
Started by AirNav Development, September 10, 2009, 03:34:09 AM
pjm
Quote from: AirNav Development on September 14, 2009, 03:48:32 AM
4- PJM: waiting for email (we believe it is a flight time-out error);
More info please - what are you waiting for and who do I send it to.
Quote from: AirNav Development on September 14, 2009, 03:48:32 AM3- Tarbat: waiting for email;
Email sent.
Simple answer is - I don't know if the route problem is corrected.  I reported problems with it running over Saturday day/night.  Aleksey then asked me to run RB with /DEBUG /LEVEL2.  But traffic levels were low, and I saw no route errors yesterday.
You can either wait another day, and I'll run with /DEBUG /LEVEL2 today and report any problems.  Note that I'm out most of today at the hospital again, but I can leave RB and DBWIN32 running all day and review tonight.
Or if you must have a decision now, I'd say, no, the route problem is not corrected.
I'm running the new beta, but I'm still seeing the wrong number in "Aircraft History" in MyFlights.  I have:
No flights shown as 1
1 flight shown as 0
2 flights shown as 1
etc.....
abrad41
Chris
I am having same problem here as well.
Just sent you a msg mate.
Andy
Quote from: AirNav Development on September 14, 2009, 03:48:32 AM2- "EDIT: Using the Airport Locate button causes the special cursors to dissapear.": Corrected as well as the splitter bard disappearing.
Not corrected.  Not sure which button caused it this time (maybe Show All), but I've lost the precision select and double-arrow cursors again :(
abrad41
I lost the double-arrow cursors after about 2 mins of running the new beta, but if you click close to the edge you can still resize the information window.
Andy
Stranger still.  After a few more minutes,  the precision select and double-arrow cursors are back again.  I have no idea what I'm doing to make them appear/dissapear.
All I've been doing is:
Accessing preferences - ftp settings
Zooming in/out - centreing on home and other airports
Selecting aircraft
abrad41
I have just restarted RB and the arrow is not there at startup, but as I said before, If you click on the edge you can still resize the information section.
Andy
abrad41
When I restarted the RB, I lost all my alerts in that section, they were not saved at close down.
EMA
Not seeing this double arrow problem. When I hover the pointer over the box edge the double arrow appears.
We have one answer to all of this: Microsoft Windows! :-)
One application should work exactly the same way on every computer but...
More work here. Stby for a few hours for a answer to all of the above.
EMA
Quote from: AirNav Development on September 14, 2009, 02:42:31 PM
Are you going to ask us to convert to Linux?  :-)
#87
OK - downloaded today's version, and I can't get a double-headed arow mouse pointer on the map edge at all, but I can still drag it.
Almost all routes are showing up fine, but I've had one oddity - a route in the table not showing on the MyFlights grid, but showing up in MyLog. The flight then went to the network grid, and the route showed up there. See pic below. In the table the route's CH date is over a year old.
Also, no matter how many times I change it G-FLBB keeps showing ... as the aircraft type!
Everything else is behaving fine so far.
#88
I've just had another example of a missing route - here's one with route with a recent CH date that isn't showing the route in MyFlights or MyLog. I closed the application and when I reopened it, the route showed up in both!
Oh, the map resizing pointer appeared for a while when I restarted, but has gona again now.
Okay, I left this version running all day whilst we were out, with /DEBUG /LEVEL2.
Out of 688 flights:
- 133 have no Flight ID, so are excluded from this testing.
- 538 have the correct route data (ie Flights.route = routes.NO - routes.ND).
- 17 have route data in MyLog, but the route has not been saved in the route table.
So the only problem now is routes not getting written to the Routes table in Navdata.  I've attached the DEBUG file.  The routes that have not been written to the routes table are:
- AFR084U
- DAL097
- DLH430U
- DLH440U
- TCX083K
- UAL901U
