V3.04 Available
Started by AirNav Development, September 10, 2009, 03:34:09 AM
New exe available.
Double headed arrow problem finally corrected (pls confirm).
Aircraft history count corrected.
Routes not being saved/route problem: Rod and Tarbat will be contacted by Aleksey today.
New exe at:
http://www.airnavsystems.com/download/anrb/beta/anrb.exe
pjm
Quote from: AirNav Development on September 15, 2009, 03:54:30 AMDouble headed arrow problem finally corrected (pls confirm).
Same as before - it works for the first couple of minutes then no more double headed arrow to be seen (but you can still resize by guessing where the spot is)
From limited testing the aircraft count looks ok so far.
EMA
Working fine, no problems with the double headed arrow comes up every time as before.
#93
Yep, so far so good.  I've still got the double arrow and precision select cursors.
Skies are nice and busy today, so I should be able to do some thorough testing of logs, routes, etc.
Andy (I think) asked if my ftp upload was working okay with this beta.  Yes it does, but I'll run it for a while today to confirm again - http://www.tarbat.gofreeserve.com/radarbox.htm
abrad41
#94
Yes I have got the double arrow and precision cursors.
Aircraft History = Everything looking good, apart from if a aircarft has no history, it is showing (1) in the title. see attachment below
Chris, Yes the ftp is still not working even with the right details entered, think it must be something this end, will try and sort when I have more time.
Andy
abrad41
As far as the ftp upload is concerned, I get "FTP Upload Status: Connection established. But no upload.
Andy
pjm
Quote from: abrad41 on September 15, 2009, 09:12:38 AM
FTP working fine here, although RB uploads to another machine on my Local Area Network, Where a different program, uploads the RB file every 10 minutes to my webserver (with some other stuff).
http://www.petermcgrath.info/weather/RadarBoxScreenShot.gif
abrad41
Everything fine now with my FTP.
Made some miner adjustments and working ok.
Andy
Quote from: abrad41 on September 15, 2009, 08:49:21 AMAircraft History = Everything looking good, apart from if a aircarft has no history, it is showing (1) in the title.
Sometimes shows 2 as well when there's no aircraft history.  If this is proving so difficult to fix, I still think the easiest solution would be to just remove the number of aircraft!!
EMA
Quote from: tarbat on September 15, 2009, 11:44:41 AM
I agree with that, this seems to be a stable version.
The good news, from my perspective, is that routes are being correctly written to MyLog.
Quote from: tarbat on September 14, 2009, 06:19:42 PMSo the only problem now is routes not getting written to the Routes table in Navdata.
Looking at today's log, I reckon this is connected with aircraft that frequently change their Flight ID throughout a flight.  Take this case of F-GISD switching between AFR083 and AFR083U.
I'm not sure if this really needs to be fixed.  It's certainly not a showstopper in my opinion.
abrad41
#101
After about 2hrs of running the RB, this is what has happened(see Below)
Lost all aircraft off of screen and my flights frozen.
EDIT When restarting the RB everything is back to normal.
EDIT But while it was frozen, it was still sending a screenshot via Ftp.
Andy
EMA
Andy did you loose usb connection?
I have been running RB since 8am this morning with no problems.
Kevin
abrad41
I don't think so, but I must admit I did not check the usb, I will keep a check on it.
I was having this problem with v3.02 and v3.03, running Windows XP Sp3, But since then I have a new Motherboard with a Phantom triple core proccessor and 4GB of DDR3 Memory and I am now running Vista home premuim.
Andy
EMA
Are you using the same USB cable to the RB with you new system?
