Author Topic: No Maximum Range Diagram  (Read 5616 times)
f6gsg
  • Electa L12
« on: November 26, 2007, 08:32:58 PM »
Hello,
Since this morning, if i want to see the Maximum Range Polar Diagram,
if i switch the button, No polar Diagram and all information like Airport, Road,
outlines are light off !!!! (toggle mode)
And also no trail visible ?
Did I modify anything ?
Other function work well.
What's wrong
Patrick
Re: No Maximum Range Diagram
« Reply #1 on: November 26, 2007, 09:09:08 PM »
Hi Patrick,
Sounds a bit weird. Have you tried closing the software and starting it again?
If so try a reinstall, seems something may have got corrupted.
Hope that helps.
f6gsg
  • Electa L12
« Reply #2 on: November 26, 2007, 09:27:15 PM »
hi AirNav,
yes i try to restart, no change !!!
one way, i have use my RadarBox on my portable for a demonstration
yesterday ... it's run well on my portable. (but's it's only the
hardware that i move).
Tomorow, i will re-install the software.(now it's too late)
Patrick
« Reply #3 on: November 26, 2007, 09:39:38 PM »
Patrick,
Have you changed and saved your color settings?
Maybe you have changed the color of the polar diagram and trails to the same color as your background color?
f6gsg
  • Electa L12
« Reply #4 on: November 27, 2007, 09:06:05 PM »
i have re-installed the software, and now all is OK.
i think that some file was corrupted !!!
Patrick / F6GSG
