V3.05 Available
Started by AirNav Development, September 18, 2009, 05:44:56 PM
EMA
Green from me, stable as a rock.
pjm
Quote from: AirNav Development on September 25, 2009, 11:00:07 PM
Full install available at:
http://www.airnavsystems.com/download/anrb/anrb306betasetup.exe
Please try the full install above and let us know the results.
AirNav - Can you please check the version you have included in the full install package.
it is 2009/09/24 06.06 and I have 2x later versions of v3.06b than that.
Also not sure if it is by design, or accident, but installing the full version overwrites any existing log file in the directory (so you lose the history). No problem for me as I have backups :), but may catch out some others....
CAM
Airnav Support,
See post 60 for PC spec.
I will install the full version and run today and see if I still have the issue.
CAM
#153
Before running this new beta, I file-compared back to my current installation to look for what's changed:
1. D008.DAT file still needs updating to include military flags, etc. from my latest version.  Same applies to the FLAGS folder.
2. The following files are newer in this new installation.  I'm assuming this is another update to the navigation aids database.
D009.DAT - completely new file
L004.DAT
L006.DAT
L009.DAT
I'll now get on with testing this installation.
pjm
Quote from: tarbat on September 26, 2009, 08:42:33 AM
I don't have it here - maybe something to do with realtime live network?
#155
Odd - I haven't got a D009.dat and I've got the real-time network.
AirNav - I sent you a new set of logos dated 23-9-09, but that hasn't got into this update. It will make life easier for everyone if you could issue that one.
Quote from: RodBearden on September 26, 2009, 12:06:25 PMOdd - I haven't got a D009.dat and I've got the real-time network.
Don't worry.  D009.dat dissapears after you run Radarbox.  Looks like some database updates.
So we are just waiting for CAM feedback and for all the new files to be sent to my email.
CAM
Airnav,
Left the full install running yesterday and last night.
Came to it this morning and My flights were OK, then went to network and could not select any aircraft and once it starts this cycle it will not let you select anything and it go's into not responding mode.
Looks like it may be an issue with my PC setup etc as no one else is having this other than abrad who is now away and cannot test.
DVDW
The complete setup is running very smooth overhere.
Dirk.
CAM
Airnav,
V3.06 from post #85 looks to be the most stable on my PC, what changes were made to later versions than this ?
CAM
CAM: we are not sure of the changes made but they were only corrections to the reported problems on this forum (not implementation of new features).
CAM
Airnav Dev,
Whatever the changes were it made a difference to my PC/RB performance.
As only 2 out of 12 testers (17%) have issues are you going for release ?
CAM
RNAGG
Hello everybody!
Follows the position of the tests I did:
In the Notebook with Vista and 2 GB:
Sometimes the system crashed and had to restart, especially when connected to the network. With local flights not notice problems.
The PC with Windows XP and 4GB:
Did not find any problem with both local flights as when connected to the network. It seems that with XP and more memory your system has an excellent behavior.
I think this version is ready for release.
