V3.05 Available
Started by AirNav Development, September 18, 2009, 05:44:56 PM
Ah - OK - I've only ever used the Advanced filter for altitude. Your tip works fine, but this behaviour is still a bit bug-like, isn't it? Mustn't let this delay the release, though.
OK, I'm back and testing :-)
I've tried to repeat the altitude filter map freeze problem, and everything is working just as advertised now.  The only thing that I did different this evening was to put EGLL into the SmartView > Select Airports box and hit Enter.  This box was empty but the Auto Set QNH was ticked.  Is there any chance that this was the problem?
A bit of background on how I ended up here:
- Renamed my RadarBox directory to avoid overwriting with the new install.
- Did a completely new install using the full download posted.
- Ran this new install briefly to make sure all was OK
- Exited RB and renamed the new install directory to New
- Renamed my previous RB directory to the correct name.
- Copied the anrb.exe from the new installation to my original directory to give me all my custom outlines, D008.dat file etc
- Ran RB (new exe in old directory) and this is what gave me the empty Select Airports box.
Maybe nothing to do with my map freeze problem, but that's the whole story :0)
RB running without any problems now with the Altitude filter set to 0-15000.  Testing continues, but everything looks good!
Still testing and still running fine - solid as a rock :-)
EMA
No problems with mine on three PC's
Frank
Very stable, no problems om my PC's either
Frank
pjm
Quote from: Allocator on September 28, 2009, 02:29:09 PM
I suspect that you are using the Quick Filters, not the Advanced Filters that allow you to filter aircraft on the map by altitude band, distance from a point or by aircraft type.  These filters work ONLY on the map, not the aircraft lists.
yes I was only using the quick filter. I'll try the advanced filter when I get home tonight - if your problem has now gone away after a fresh install, I suspect mine will be fine too. Give me 8 hours or so for an update (these timezones are a killer for quick replies sometimes...)
So we will consider this version as the final one. We're just waiting to have the latest version of the flags/logos files.
GlynH
As I said before this is the best version I have seen so far...i hesitate to use words like rock-solid, perfect etc. but it looks like we have a winner!
Thanks AirNav...
I am also starting yet again from a virgin database to rule out any problems that might be in the 9,000+ database from the beginning of September.
One thing I notice when installing a new version - although it remembers preferences, Alerts etc. I always have to fill out the SmartView details which loses all of my previous registrations.
Not a major problem of course just wondering why the discrepancy - surely if it remembers Alert details than it should be consistent and also remember SmartView details?
Thanks & regards,
-=Glyn=-
pjm
tried the advanced filter - no lockups here - all working as expected.
#190
Quote from: AirNav Development on September 29, 2009, 01:39:25 AMWe're just waiting to have the latest version of the flags/logos files.
You should already have the latest D008.dat file and FLAGS folder from me.  See post #153
Tarbat: I confirm we have it on our setup but RodBearden reported we didn't have. So I'm waiting for his reply to give release the version to the public.
GlynH
Quick question for you guys using Vista...I hear things about the Virtual Store and a friend of mine always seems to lose his database when upgrading.
What is the best way of installing the full 3.06 Beta version on a Vista system leaving his existing ANRB setup intact please?
A quick search for virtual store returned no hits...
Just how do you Vista guys here install new releases?
Thanks & regards,
-=Glyn=-
I sent the latest logos to Andre last week, and again today - today's file contains 2000 logos!
Some of them are duplicates for multiple registrations, but we don't need to point that out ;-)
I hope the AirNav email system is working OK now.
We got everything and the latest, final release is below.
Please review it and we will make it available to the public tonight.
The last full install is available at:
http://www.airnavsystems.com/download/anrb/beta/ANRB306BetaSetup.exe
The upgrade (for users with V2.xx) is available at:
http://www.airnavsystems.com/download/anrb/beta/ANRBUpgradeto306Beta.exe
