Author Topic: V3.05 Available  (Read 56502 times)
DVDW
  • RadarBox Beta Testers
Re: V3.05 Available
« Reply #195 on: September 29, 2009, 07:12:35 PM »
The last full install is available at:
http://www.airnavsystems.com/download/anrb/beta/ANRB306BetaSetup.exe
When I try to start the full install I always get the message 'The setup files are corrupted. Please obtain a new copy of the program'. I suppose there i something wrong here... (downloaded the setup-file several times)
Dirk.
Re: V3.05 Available
« Reply #196 on: September 29, 2009, 07:13:56 PM »
Dirk,
What is the size of your downloaded file?  Maybe you haven't got the whole file?
DVDW
Re: V3.05 Available
« Reply #197 on: September 29, 2009, 07:20:51 PM »
Hi Allocator,
The size of the file is 101.344 kB.
Greetz,
Dirk.
DVDW
Re: V3.05 Available
« Reply #198 on: September 29, 2009, 07:22:29 PM »
Just downloaded the file a fourth time, same size 101.344 kB.
Greetz,
Dirk.
Re: V3.05 Available
« Reply #199 on: September 29, 2009, 07:43:53 PM »
The file is 100mb and seems to be fine and others can download it. Try restarting your machine and download to a different area and it should be fine.
    • Rod's RadarBox Downloads
Re: V3.05 Available
« Reply #200 on: September 29, 2009, 08:09:34 PM »
I'm having the same problems as DVDW. I too will reboot and download again.
Re: V3.05 Available
« Reply #201 on: September 29, 2009, 08:12:55 PM »
I get the same error.  It took ages to download - >20 minutes.  Has anyone downloaded this okay?
I won't be able to beta test tomorrow - hospital again.
DVDW
Re: V3.05 Available
« Reply #202 on: September 29, 2009, 08:18:13 PM »
Hi Airnav,
Restarted the computer and downloaded the file to another location but no joy...
Still the same result 'The setup files are corrupted. Please obtain a new copy of the program'
Dirk.
DVDW
Re: V3.05 Available
« Reply #203 on: September 29, 2009, 08:20:48 PM »
Download tooks about 5 minutes overhere, speed around 400 kb/sec.
Re: V3.05 Available
« Reply #204 on: September 29, 2009, 08:32:39 PM »
On slow mobile broadband I'm afraid, with an estimate of 1 hr 30 min to download this, so I can't test the download I'm afraid.
Re: V3.05 Available
« Reply #205 on: September 29, 2009, 08:34:46 PM »
We are uploading them again. Stby.
DVDW
Re: V3.05 Available
« Reply #206 on: September 29, 2009, 08:38:09 PM »
I will check tomorrow morning... Going to sleep now, early work :-(
Re: V3.05 Available
« Reply #207 on: September 29, 2009, 09:31:39 PM »
Please try again now. Both files are there and ready.
GlynH
Re: V3.05 Available
« Reply #208 on: September 29, 2009, 10:15:59 PM »
I had a similar problem with the previous full 3.06 download yesterday - when I double-clicked the file it reported the package was corrupt.
Downloaded it again earlier today and it was fine...
Just taking this latest one and it seems to be downloading OK although slow at @150KB/sec
By way of comparison while this is still downloading I can pull down a file from Symantec @ 500KB/sec...
No major problem...it will take a while longer that's all...
The latest full package downloaded with no issues and installed correctly.
As I have mentioned before though although it remembers most of my preferences I have to populate the SmartView registrations every time I install a new version.
To retain consistency shouldn't this pick up the previous settings?
Testing commenced!
-=Glyn=-
Re: V3.05 Available
« Reply #209 on: September 29, 2009, 10:21:37 PM »
Ahhh... that's better - downloaded successfully, and the correct flags and logos are there. As Glyn says, all the settings apart from SmartView have transferred OK.
If this is exactly the same ANRB.exe as the previous release, and I suspect it is, it looks good to go!
