Silhouettes
Started by Jeremy, September 20, 2009, 03:11:26 PM
Jeremy
How do I attach a particular silhouette to a Registration of a particular aircraft? What I want to do is find a sillouette for Air Ambulance helo and attach it to the local G-HBOB.
J.
G4DOQ
QRZ.com
Quote from: Jeremy on September 20, 2009, 03:11:26 PM
J.
Jeremy,
Do you mean a silhouette, or do you mean a flag?  G-HBOB is an EC35 helicopter and this silhouette is included with the RB software.
If you mean a 'flag' then this is selected based on the Flight ID, so can be set up using the D008.dat file.
Tarbat is the man to advise here I think :-)
Silhoutte is derived from the short aircraft type - eg EC35
Flag is derived from the ModeS hex code, using the D008.dat file
Logo is derived from the Flight ID - Rod's the expert on logos!!
#3
Jeremy - if you meant a logo, here's one I've just done for you - I'll post it in the Logos thread too. There is also a general-purpose Air Ambulance logo in the logos thread that you could use.
Remember that logos are generated by the Flight ID - no ID, no logo.
Jeremy
Quote from: tarbat on September 20, 2009, 03:29:53 PM
Does the aircraft type i.e. EC35 come from the aircraft or where? I see G-HBOB but no Type. I sometimes see the FlightID and sometimes not.
J.
G4DOQ
QRZ.com
Jeremy - the Type code is derived from the Navdata database by looking up the Mode-S code transmitted by the aircraft - it doesn't transmit it itself.
The flight ID is broadcast by the aircraft along with the Mode-S code, and can be set by the aircraft crew, so they can type it, mistype it, or not bother!
Jeremy
G4DOQ
QRZ.com
Quote from: Jeremy on September 22, 2009, 03:11:29 PMI sometimes see the FlightID and sometimes not.
You will see more FlightIDs (and therefore more operator logos) when V3 is released as it decodes some that V2 doesn't.
Jeremy
No. What I meant was that sometimes I see the Registration and Flight ID and sometimes just the Flight ID, from the Air Ambulance Helo. Presumably the mode-s data packet gets corrupted and I only receive some of it.
J.
G4DOQ
QRZ.com
Jeremy
Quote from: Allocator on September 20, 2009, 03:18:34 PM
J.
Jeremy,
J.
Jeremy,
I think this should be a EC135
J.
G4DOQ
QRZ.com
Full Type is Eurocopter Deutschland EC-135 T2+
ICAO type is EC35 - as used in the 'Short Type' in the RB databases.
http://www.flugzeuginfo.net/table_accodes_en.php
Aerotower
Good afternoon Rod,
Is not possible to arrange a Silhouette Logo for the MRTT (tanker A330)?
Thanks,
Aerotower
Hi Aerotower
As far as I know the MRTT doesn't have its own ICAO code, so won't show a separate silhouette.
I don't create the formal silhouettes. Ian K is the man.
BTW We already have a proper thread for silhouette discussion here: http://www.airnavsystems.com/forum/index.php?topic=1290.0
IAN K
Thanks Rod, as you rightly say the MRTT doesn't have it's own code but I have adapted the A330 silhouette to include the refuelling boom and have renamed it MRTT.
Aerotower
Many thanks to both!
PS-I asked a silhouette of the MRTT because I pick several times the EC-330 of the Australian Air Force is still in testing.
Cumps
