Author Topic: Alert notification message  (Read 2306 times)
« on: September 22, 2009, 10:35:53 AM »
Strange occurrence never happened before. The alert notification message has come up in the bottom right hand side of the screen but has appeared without the 'cross' sign in its top right hand corner. It means I cannot get rid of the message as there is nothing to click on. Any suggestions ?
    • Rod's RadarBox Downloads
Re: Alert notification message
« Reply #1 on: September 22, 2009, 11:42:49 AM »
Is there a thin dotted bit at the top of the message? If so you should be able to use that to drag the message onto the screen and the cross should become visible.
« Reply #2 on: September 22, 2009, 03:41:45 PM »
Thanks Rod. Should it happen again, I'll give that a go. I finished up having to switch off the RB and restarting it in order to clear the message. As I say it has never happened before. Looks as if I may have inadvertantly altered the screen size so that the cross hasn't been showing when the message came up. Me and computers !
Cheers,
Edit: Just had another alert message and the small cross at the top right of the box is showing ok therefore everything would now appear to be ok.
« Last Edit: September 22, 2009, 03:44:33 PM by EK01 »
