RELEASED - AirNav RadarBox 2009 - 3.06 Beta
Started by AirNav Development, October 01, 2009, 01:03:41 AM
marcdeklerk
ok thanks, im sure Airnav will have a look at it,
Airnav may I also be part of the Beta test team please
thanks Marc
John Racars
Hi Support and All,
I like to thank AirNav for the newest (3.06) Beta in the first place. I installed this version in between succesfully.
I think there are still problems with the correct showing of flightid's and routes. Here is an exemple: here you see two different a/c with the same flight-id:
Some minutes later the flightid of PH-KZL changed (not the routing):
Here you see what my local route-database say about KLM1722:
Anyone any idea what happens here?
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
dumpty
Airnav
I have done a total reinstallation and I am still getting 30 second updates on the live network(not 20)!
Help Please.
nortonbeak
I find that trying to get v3.06 to connect to ANAD is more tricky than with v3.02.
9 times out of 10 with v3.02 I would connect successfully.
Now, with v3.06 I find that I have to stop and start RadarBox and stop and start AirNav Decoder several times before they will connect to each other.
dumpty
Airnav Support
I have a subscription and I am recieving the live network(Not today) but it is every 30 seconds not 20 seconds as it should be.
Simon
John Racars
Quote from: John Racars on October 02, 2009, 09:10:36 AM
Support,
In other words: can you confirm that problems like these I reported before are NOT solved with the new (3.06) version so that I can stop reporting Flight ID and routing-information errors?
13 NM East of EHAM
ANRB:
Jeremy
Quote from: dumpty on October 02, 2009, 10:50:17 AM
Airnav Support
Simon
The same here.
In reply to Airnav on the questions I asked on the other thread, I also have a subscription.
The patch worked OK on my desktop running XP, just as it did send out an error message but then worked, but Vista will not allow it to run.
J.
G4DOQ
QRZ.com
GreekSpy2001
#53
Quote from: GreekSpy2001 on October 01, 2009, 05:35:40 PM
Definitely referring to on screen alerts.
The scenario I have is an arrival at LHR might not be seen due to inbound routing but outbound would be seen so a second alert is needed by me.  Maybe a feature request if its not a bug.
Graham
Further to this I have had D-AISU alert both inbound and outbound of LHR today.  Therefore the onscreen alerts work for more than one hit in a day.  So it seems the onscreen alerts based on registration are still liable not to show 100% of the time.  :-((
Graham
bearcat
Hi Romdouk
The reason you picked up some wrong logos is that
S6 is the IATA airline code for Star Airlines
AF is the IATA airline code for Air France
These code are cross referenced in your Airline database to the ICAO code to then show the relevant logo.
The blank one os because there will be no IATA/ICAO code and therefore no logo
Stewart
John Racars
Quote from: romdouk on October 02, 2009, 12:54:31 PM
Have been operating V3.06 for 2 days and everything seems OK
Hi Terry,
I am happy for you but it is hard to believe for me. Did you see what I report above today? Or don't you see this as "a problem"? If so then I can understand that you are content.
13 NM East of EHAM
ANRB:
Fenris
Quote from: John Racars on October 02, 2009, 03:17:03 PM
Hi Terry,
He did say that he sees duplicates but only when he orders the flights by distance.
TedLoon
just to chip in my t'uppence (two penn'orth) worth. My RB clock is still an hour behind my PC's..
Colin in England
Quote from: TedLoon on October 02, 2009, 05:13:43 PM
Colin in England
The RB clock shows UTC (or Greenwich Mean Time for those of you old enough to know about GMT - or ZULU time for those in the military!)
http://www.worldtimeserver.com/current_time_in_UTC.aspx
TedLoon
Allocator, I can live with that, but what's this about from the OP>>>>>
Previous official full list of suggestions/improvements:
- UK/Ireland Time on status bar now shown correctly;
