Main Menu
neckwork down?
Started by davec, October 02, 2009, 07:38:14 AM
davec
hi i have just lost all network traffic ,is it down?,nothing was changed
davec
davec
thanks tarbat, i was worried that i had done something wrong, tarbat could you tell me again how to transfer my data onto the new 3.06, i am doing something wrong the 2 files are the same ; mylog,db3bak andnavdata,db3bak,
thanks davec
sterigia
network down here too, same problems as v 3.01?
frank
ciao.
frank
We will take a look and no its the same as 3.01 as this is a server issue.
parsley
yeah appears to be a network problem as getting a "Unhandled Exception: Host 'C6604-126223' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'  on my network account status....initially had a minor scare because it coincided with me installing 3.06 !!!
cheers
p
dl1812
cheers
p
[/quote]
Yep, me too; especially as i've just installed Windows 7 as well.
That's a relief (to us at least, if not AirNav !)
g0seg
Quote from: davec on October 02, 2009, 07:38:14 AM
davec
Yep, same problem in Pontefract - network down about 0830 local. Roger
MrT
Not running for me either.
Its been off for a few hours
Northern Watch
Just downloaded new version last night and now find I cannot get connected. thought it was me as only just bought the system.
K
puddy
Mine down just re-loaded my laptop (tape)
Wanted to track  airforce 1  over the UK this morning
Puddy
Radar Box & AOR8200 mk3 scanner
South Lincolnshire near Boston (UK)
Roadrunner
Quote from: puddy on October 02, 2009, 10:00:30 AM
It won't track as such but only appear in the aircraft list. Also in the other direction it traversed Scotland.....
Mike
radarspotter10
hi all
why is it when the network is down i seen to pick up more aircraft locally,
and better range.
from pat.
Fenris
Quote from: radarspotter10 on October 02, 2009, 10:42:03 AM
hi all
and better range.
from pat.
Not easy to say, but it must be tied up with the algorithms that decide when to show an aircraft you can see directly vs the same aircraft coming in via the network.
It may be that the decision is not only "is it local?" but is also based on the quality of the track and the effect of the various timeouts. Airnav should be able to answer this question.
Its a case of both the algorithms and our mind :)
