Iphone app?
Started by johnnyB, October 04, 2009, 01:17:47 PM
johnnyB
Just wondered is there a Radarbox app for the iphone or itouch? If not is there one in the pipeline?
With with the launch of the real-time network it would be a very handy tool. Even if your at the airport waiting for a flight once you have an internet connection which is available at nearly all airports you can track the flight right down to the ground once theirs coverage.
The main issue surrounding this has been can you download the amount of the data needed without taking forever and also the processing required to update a map would also cause further delay.
It is something we have looked at but the throughput of the network and iphone spec don't exactly match quite yet to what we need.
itestoo
You can see a googlemaps api here compatible Iphone :
www.radarvirtuel.com/googlemaps with 5 minutes delay :)
Regard's
Laurent
LFRN
prbflight
How about an app that would allow you to copy and dispaly myLog on the iphone at least?
Paul@cyyb
