Author Topic: wrong position?  (Read 18626 times)
sterigia
  • forza paris
wrong position?
« on: October 12, 2009, 06:45:53 PM »
wrong plane or wrong position? ezy6497 from egnt to lkpr newcastle to prague. see the attached file
someone has an explanation?
frank
« Last Edit: October 12, 2009, 06:48:24 PM by sterigia »
ciao.
frank
Re: wrong position?
« Reply #1 on: October 12, 2009, 06:52:05 PM »
Or wrong Flight ID not reset by the crew?
I don't have EZY6497 in my routes database.  A Google search suggests that this flight is from Newcastle to Malta, and the return flight is EZY6498?
http://www.chevron.co.uk/malta/winter-flights-malta.asp
« Last Edit: October 12, 2009, 06:57:36 PM by Allocator »
sterigia
  • forza paris
Re: wrong position?
« Reply #2 on: October 12, 2009, 06:53:06 PM »
another just now london to turin over the med ryr04d
frank
ciao.
frank
sterigia
  • forza paris
Re: wrong position?
« Reply #3 on: October 12, 2009, 06:53:46 PM »
same crew?
ciao.
frank
Re: wrong position?
« Reply #4 on: October 12, 2009, 06:57:55 PM »
sterigia
  • forza paris
Re: wrong position?
« Reply #5 on: October 12, 2009, 07:46:34 PM »
dont know what to say. they were both in direct reception and not moving on the screen. then they disappeared from the map without moving
frank
ciao.
frank
John Racars
Re: wrong position?
« Reply #6 on: October 12, 2009, 07:47:30 PM »
I do not know where you get your informations from.....
Look what FlightStats say about this today below. I think the plane was showed correctly on your RB screen. I saw an Air Malta enroute from Malta to Amsterdam on your screen as well....
Next time you should do some more research before complain on this.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
sterigia
  • forza paris
Re: wrong position?
« Reply #7 on: October 12, 2009, 08:12:11 PM »
i got my info from the program display as you can see from the screenies. i am not complaining for once. i just needed an explanation for a plane apparently off course.
regards
frank
« Last Edit: October 12, 2009, 08:13:52 PM by sterigia »
ciao.
frank
sterigia
  • forza paris
Re: wrong position?
« Reply #8 on: October 12, 2009, 08:21:33 PM »
isn't this in the wrong position?
frank
ciao.
frank
Re: wrong position?
« Reply #9 on: October 12, 2009, 08:33:06 PM »
Frank,
I think that there are a few questions here.  Firstly, the route shown by RadarBox depends upon the Flight ID.  The Flight ID is set by the aircrew, so there are a number of possibilities here:
- First, some of the routes you are showing are not in my database, so how did they get into your database?  Did you enter them manually, or did they autopopulate?
- If the crew have set the wrong Flight ID, or have not changed it for the next leg of the route, then it will give a wrong route
- Or of course, the location of the aircraft on your RB map might be wrong, but I think that this is the least likely of the possibilities.
sterigia
  • forza paris
Re: wrong position?
« Reply #10 on: October 12, 2009, 08:41:49 PM »
i did not enter anything manually, i am not so skilled so it must have been an autopoulate thing.
if the crew did not change flight id then how do i get wrong coordinates and wrong displays on my map via direct reception. does the aircraft give out wrong coordinates? there is something i am missing and do  not understand well
saluti
frank
ciao.
frank
John Racars
Re: wrong position?
« Reply #11 on: October 12, 2009, 08:45:22 PM »
I am sorry but I think the position is correct. Flight  TOM8BH  is  LIRN-EGCC so it looks the position is correct. I think your flight-database need some maintenance!
13 NM East of EHAM
ANRB:
Re: wrong position?
« Reply #12 on: October 12, 2009, 08:49:43 PM »
There is no mystery here.
The AirNav server autopopulates EZY6497 as EGNT-LKPR (Newcastle-Prague) so if you don't have the correct Newcastle-Malta route in your local database that's what you'll get.
dumpty
Re: wrong position?
« Reply #13 on: October 12, 2009, 08:49:56 PM »
Well said John
Some people just love to focus on the negatives and forget about all the superb positive features of the radarbox!!
sterigia
  • forza paris
Re: wrong position?
« Reply #14 on: October 12, 2009, 08:51:05 PM »
what must i do then, help appreciated, the database came with the program, freshly installed
frank
ciao.
frank
