Author Topic: SBS-1 Meter Lite  (Read 30861 times)
SBS-1 Meter Lite
« on: October 17, 2009, 12:18:37 PM »
Re: SBS-1 Meter Lite
« Reply #1 on: October 17, 2009, 03:31:54 PM »
Nice, downloaded and running now :-)
OKC-Steve
« Reply #2 on: October 17, 2009, 03:56:50 PM »
This will consume one socket.  Does RB allow more than 1 socket connect in the new versions?  I think Basestation allows 5.
« Reply #3 on: October 17, 2009, 04:04:39 PM »
v3.07 allows at least 2 connections on port 30003, from testing I've done.  It may allow more.
« Reply #4 on: October 17, 2009, 04:09:28 PM »
I'm running SBS-1 Meter Lite and JSTARS v1.2.5 and they are both working well together :-)
« Last Edit: October 17, 2009, 04:12:38 PM by Allocator »
OKC-Steve
« Reply #5 on: October 17, 2009, 04:25:34 PM »
OK good, I didn't keep up.  I think it was version 2 that only allowed one.
He makes me mad, because I struggle greatly with Java GUI stuff, and his looks so good :-)
« Last Edit: October 17, 2009, 04:27:47 PM by OKC-Steve »
« Reply #6 on: October 17, 2009, 05:04:52 PM »
Here is my first one hour chart for the West Midlands (UK).
pjm
  • RadarBox Beta Testers
« Reply #7 on: October 17, 2009, 09:50:29 PM »
Nice program, they should build a panel like this into Radarbox!
Sunday morning over Sydney
« Last Edit: October 18, 2009, 01:33:32 AM by pjm »
pjm
« Reply #8 on: October 19, 2009, 02:02:04 AM »
Very useful program. You can see below the difference between my old Antenna (I reinstated it between 10.55am and 11.20am this morning, and the AirNav RADAR-EXTENDER Antenna. I wonder what the difference will be once I get the preamp working :)
jannuh
« Reply #9 on: October 20, 2009, 09:56:31 AM »
Really nice program, used it to test connection between RB and PC, have an usb-extender in use (5 mtr.); tested yesterday with a usb2tcp interface.
Where range (Polar Diagram) was the same with both options, I did receive more messages with the usb-extender; must admit usb2tcp was in disadvantage in this test, signal had to go through 3 routers, that's maybe too much  ;)
Test it later with direct connection to extra networkcard in the PC which runs RB.
This screenshot is from lateron (19/10 1200 - this morning):
John Racars
« Reply #10 on: October 20, 2009, 06:55:23 PM »
Hi All,
Looks verry nice indeed but chart is not working with me until sofar. What should I load as "SBS-1 Meter log"? I do not see any *.sbs file in the AirNav Systems directory anyway.....
Any help will be verry welcome. Thanks you in advance!
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
jannuh
« Reply #11 on: October 20, 2009, 07:50:40 PM »
Hi John,
First start the SBS-meter, configure & start it.
Then load the SBS-chart, load the file auto made by sbs-meter (made on actual time from start)
It's in the same map overhere.
GL
Btw RB has much higher counts on messages then SBS-meter gives.
But the meter gives a nice overview ;-)
« Last Edit: October 20, 2009, 07:52:29 PM by jannuh »
John Racars
« Reply #12 on: October 20, 2009, 08:46:06 PM »
Hi Jannuh,
Thank you. It is working verry well now!
13 NM East of EHAM
ANRB:
radarspotter10
« Reply #13 on: October 21, 2009, 09:20:01 AM »
hi
sorry for this but i am doing something wrong.
i download and open both software on my desktop
my airnnav is also running, when i open sbs-meter and click on
load sbs meter log, where do i find the SBS-chart
from pat lost
Storm
    • KuwaitStorm
« Reply #14 on: October 21, 2009, 10:15:35 AM »
Didn't work for me at all I'm running 3.0.6 could that be the reason?
