Author Topic: Not always getting alerts  (Read 14179 times)
radarspotter10
Re: Not always getting alerts
« Reply #15 on: October 27, 2009, 05:13:06 AM »
welcome to the forum RadarSpotter01
enjoy. pm me your callsign.
from pat
Fenris
« Reply #16 on: October 27, 2009, 07:44:14 AM »
from pat
Google is your friend Robbie!
sterigia
  • forza paris
« Reply #17 on: October 27, 2009, 09:01:08 AM »
ok itìs a bug. do the developers know it?
ciao
frank
ciao.
frank
« Reply #18 on: October 27, 2009, 09:09:38 AM »
Squawk alerts don't work in any of the 3.x Betas. It's a bug.
How come I just received a squawk alert then?
sterigia
  • forza paris
« Reply #19 on: October 27, 2009, 09:44:48 AM »
the range works but the squawk codes do not, at least for me , or there have not beeen any emergencies declared since io set up the new beta
ciao,
frank
ciao.
frank
Fenris
« Reply #20 on: October 27, 2009, 10:38:51 AM »
Maybe because you don't have aircraft un-highlight themselves either?
Your installation seems to be blessed Tarbat... :)
« Reply #21 on: October 27, 2009, 11:26:33 AM »
I have alerts set up under Sqawk codes , mode S codes and registrations and they are all working for me both the message on screen and the sound. I am using version 3.06. Maybe a stupid question but have you ensured you have  ticked the appropriate boxes.
« Reply #22 on: October 27, 2009, 11:41:26 AM »
And the key to solving these types of problem is to understand the differences between my installation and those having problems.  On alerts, check that each squawk code is on a new line, and that there aren't any extra spurious new lines in the list of squawk codes.
Fenris
« Reply #23 on: October 27, 2009, 11:54:15 AM »
While I would agree with what you say, I think it's important that the program doesn't allow a setup that won't work. It should either give an error, or better, correct the error when it stores the alert settings in the registry.
sterigia
  • forza paris
« Reply #24 on: October 27, 2009, 01:49:21 PM »
can someone give me  the most used  squawk code, i'll try that one
ciao
frank
ciao.
frank
MikeC
« Reply #25 on: October 27, 2009, 01:53:41 PM »
7000
sterigia
  • forza paris
« Reply #26 on: October 27, 2009, 03:12:32 PM »
thanks,
frank
ciao.
frank
sterigia
  • forza paris
« Reply #27 on: October 27, 2009, 03:16:18 PM »
i just got a popup with code 7000, seems there were no emergencies transmitted in the past days,
sorry for the trouble
again many thanks for help
ciao
frank
ciao.
frank
Fenris
« Reply #28 on: October 27, 2009, 03:27:26 PM »
ciao
frank
7700 codes are relatively rare, so they are not the best test of the alert system.
I'm pleased to see that if I get an alert for say registration and aircraft type, that the alert shows both reasons in the popup.
sterigia
  • forza paris
« Reply #29 on: October 27, 2009, 03:33:10 PM »
a pity i cannot click on the alert popup and go to the plane on the screen directly to see where it is.
ciao
frank
ciao.
frank
