Not always getting alerts
Started by GrizzFlyer, October 25, 2009, 05:49:21 PM
GrizzFlyer
Occasionally I do not get alerted for aircraft that are on my alert list.  Just watched UAE9911 land at KTOL via Radarbox, and it is on my alert list.  It never triggered, and I tracked it all the way to the ground.  Checked my alert list again, everything looks OK.  Flight ID box is checked, that flight number is on my list.  Seems to work fine for registration alerts.
I was not getting flights from the network (my choice at the time), does that have anything to do with it?
Johnn
Yes, I Agree, This Has Been Happening To Be Recently Too, I always have it on when the aircraft is within 10 nm of my location, but it does not trigger on to alert me?.
Sorry I could not help, as I have the same problem.
Johnn
Johnn -
CarlosAbreu
Hi to all
The same hapenned to me one week ago with a flight RZO128 from LPPD to LPPT, all data were correctly introduced and no alert was made.
Brgds
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
sterigia
#3
i put up alerts for emergency squawk codes with version 2 i got a pop up and a sound even if the aircraft was from the network. now i get nothing. is it  a known bug or am i missing something ?
ciao
frank
ciao.
frank
Tramline
I have the same issue with B742's.  Correctly entered into the system but rarely flag up despite being seen overhead as CKS / SOO flights.
I rely upon the alert system and was the main reason for using RB.  I'm using V2.01
I have no ideas as what to do?
Anyone?
Located 2 miles South of LHR.
Jeremy
Quote from: sterigia on October 26, 2009, 04:13:01 PM
ciao
frank
frank,
Check that the check boxes in Alerts are ticked.
J.
G4DOQ
QRZ.com
sterigia
boxes are ticked, that is activate alerts for network flights and  squawk- both ticked i have 4 squawks activated separated by a simple space. must i put a semicolon or other punctuation mark between them?
ciao
frank
ciao.
frank
Quote from: sterigia on October 26, 2009, 07:51:53 PM......i have 4 squawks activated separated by a simple space. must i put a semicolon or other punctuation mark between them?
Put each squawk code on a new line (press enter), and make sure there's not a new line (enter) after the last squawk code.
sterigia
done. i have also shut down and reopened the program i'll wait and see
thanks for help
ciao
frank
ciao.
frank
Jeremy
ciao
frank
frank,
How about the boxes on the left side?
J.
G4DOQ
QRZ.com
sterigia
#10
i do not have boxes on my left side but on my right, until now no alerts play a sound and show a notificartion message are also ticked can you suggest me a prog to take a shot of the part so i can show you? freeware of course
ciao
frank
ciao.
frank
Jeremy
frank,
IN Alerts.
Tick Play a sound (then Broiwse for wav file in Data.)
and Show notification.
J.
G4DOQ
QRZ.com
sterigia
already done it will not work all the same
ciao
frank
ciao.
frank
M
ciao
frank
Squawk alerts don't work in any of the 3.x Betas. It's a bug.
RadarSpotter01
Alerts work for me OK. In 2.01
Be patient, ver 3 whatever is getting there! At least their is some development with Airnav!
