Author Topic: AirNav RadarBox 2009 - 3.08 Beta - Released  (Read 135808 times)
« on: November 05, 2009, 04:36:05 PM »
We have just finished the work and testing on the pending issues reported on previous beta version of AirNav RadarBox.  They have been properly tested by our beta team.
This time we are not releasing a full installer but just the changed .exe.
1- Download the new V3.08 executable file from:
http://www.airnavsystems.com/download/anrb/beta/anrb.exe
2- Copy it to your AirNav RadarBox folder, overwriting the existing file.
Please note that this is still a beta so errors may still exist and should be reported on this thread or to our support team at [email protected]
Jeremy
  • Jeremy
Re: AirNav RadarBox 2009 - 3.08 Beta - Released
« Reply #1 on: November 05, 2009, 07:26:19 PM »
Airnav. Screen still freezes after sorting MyFlights by Altitude. Please confirm that this was supposed to be rectified.
J.
G4DOQ
QRZ.com
Fenris
« Reply #2 on: November 05, 2009, 07:27:35 PM »
Would it be possible to post a list of what is intended to be fixed please.
Thanks!
vonsmalhausen
« Reply #3 on: November 05, 2009, 08:02:45 PM »
just installed 3.08, and i'm very happy that the problem that anoyed me the most in 3.07 : the de-selecting of flights and problems with showing the correct info seems to be corrected :-)
thanks AirNav.
« Reply #4 on: November 05, 2009, 08:08:34 PM »
J.
That's strange Jeremy - No more freezing here.
bearcat
« Reply #5 on: November 05, 2009, 08:17:28 PM »
No freezing here, tried with altitude sorted ascending and descending
jonjorobb
« Reply #6 on: November 05, 2009, 08:28:10 PM »
Maybe Im missing something - I've been running 3.08 for the past week! I went to download 3.07 and 3.08 came!
Thanks anyway :) - No issues here!
Jonjo
MW0CVW
« Reply #7 on: November 05, 2009, 08:30:51 PM »
Just Installed 3.08 on my machine.
So far now problems,i removed AVG virus checker and installed Avast virus checker.
More stable and seems to run better no freezing.
MW0CVW
Paul
NR EGNR/EGGP
BMcL26
« Reply #8 on: November 05, 2009, 08:43:31 PM »
Installed 3.08 been running for 2 hours now no problems, no freezing when sorting by any field.
Fenris
« Reply #9 on: November 05, 2009, 10:11:41 PM »
OK, well so far it looks better, the highlighting problem seems not to happen within a minute as it did before. That's a lot of progress for me!
However, the attached screenshot does show up a local flight more than 2000nm away, it was over Burkina Faso when I looked. Also it seemed to be updating regularly, and since it was showing as an ATP I'm not sure if it was meant to have ADS-B or if this was some strange garble.
So, let's chalk this one up to something odd for now. And indeed it was. I've seen two ATPs this evening that show a position which is either 12, 24 or 36 degrees North and is always 0 degrees East. Looks like something wrong in the avionics on board, or a faulty setup.
I'll try and test for a decent period over the weekend.
« Last Edit: November 05, 2009, 10:23:56 PM by Fenris »
radarspotter10
« Reply #10 on: November 05, 2009, 10:20:41 PM »
hi team.
Thanks for a great job well done,  going great hear,   no problems.
from pat.
« Last Edit: November 05, 2009, 11:25:01 PM by radarspotter10 »
Pinza
« Reply #11 on: November 05, 2009, 11:17:39 PM »
I have been running 3.08 for four hours now - with interface sorted on altitude.
Flights have come and gone from 'MyFlights' but any selected flight still in range has remained 'locked on' and in focus.
This seems to be a major improvement - many thanks AirNav.
« Reply #12 on: November 05, 2009, 11:54:01 PM »
The ATP problem is a strange one - it seems to occur on RadarBox, but I've yet to see it on SBS, and the aircraft concerned don't actually have ADS-B so I have no idea where RB is getting those coordinates from.
Jeremy
  • Jeremy
« Reply #13 on: November 06, 2009, 12:12:33 AM »
J.
Well it is still happening here. It is something to do with the screen saver. Once that is activayed the screen freezes and MyFlights list is added to but not emptied. I know the solution is to turn off the screen saver but to me that is not the real solution but cosmetic.
J.
G4DOQ
QRZ.com
Fenris
« Reply #14 on: November 06, 2009, 12:27:03 AM »
Could it be mistaking one DF frame format for another? I seem to remember you saying that there is some ambiguity with certain frames if you don't know what the interrogator sent to the aircraft.
